heater core replacement
Old Nov 26, 2016 | 07:58 AM
Rick1t's Avatar
Default heater core replacement
Gentlemen, I have a stock 98 EX, 400K, did the head gasket last Christmas.........just gave this gem to my son........We need to replace the heater core.....any Idea of a timeframe for doing this? Helpful suggestions or tip would be appreciated.
Thanks
Rick
Old Nov 26, 2016 | 08:06 AM
Honda_Cribb_GS-R's Avatar
Default Re: heater core replacement
had mine in and out with in a 2hrs not that bad but you will have to pull the dash out
Old Nov 26, 2016 | 10:05 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
If it's your first time doing the heater core, plan a weekend for it. This way you have extra time to get through it without the stress of having to get it done right now due to having to goto work the next morning.
Should be quite doable in a day.
The hardest part I found was dealing with unhooking the wire harness from the dash to get the dash out. The wiring is semi woven into the dash on the 92-95. I would think the 6th gen might be a little more so with a few more wires.
Old Nov 26, 2016 | 12:36 PM
Rick1t's Avatar
Hey, thanks for the feedback........quite a spread on time......2 hours to all day.......what were the engineers at Honda thinking......
Has anyone seen a tutorial on this somewhere? I didn't see a good youtube on the 98 series.....
Thanks
Rick
Old Nov 26, 2016 | 02:17 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
You should get the Helm's (Factory Service) manual for your car.
2 hours is for those who are well versed and have the manual and all the tools etc etc.
5 hours for skilled but never done before, and a day for someone who is plodding through without any urgency or rush with breaks and drinking beer and BS'ing etc.
Size:  134.9 KBName:  capture1.jpg
Size:  99.9 KBName:  Capture2.JPG
Size:  165.8 KBName:  Capture3.JPG
Size:  132.7 KBName:  Capture4.JPG
Old Nov 26, 2016 | 02:57 PM
mk378's Avatar
Make sure the power windows and sunroof are closed, then disconnect the battery before you start. Leave it disconnected the whole time.
Old Nov 26, 2016 | 03:10 PM
BryanM.'s Avatar
Resident Gearhead
Pulling the dash is not that bad. Some people are baffled by the location of some of the screws but I never thought they were that hard to find.
Don't plan on 2 hrs, setting aside a weekend sounds like good advice.
**Notice the directions posted don't mention dropping the steering column and wheel. IIRC it needs to be dropped down for clearance. Someone correct me if I'm wrong.
Old Nov 26, 2016 | 03:18 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Yeah, there is more instructions in the FSM for the Heater core which I believe covers the dropping of the steering column.
Notice in 20-71 image, the column is detached and lowered from the dash area bracket. On 20-70 step #2 is lower the steering column and refers to section 17 for those instructions.
I didn't have time to dig up all the pages for the heater core and instead just focused on the dash element which was step #3 of the heater core I think.
This also demonstrates why the suggestion to get the FSM for the car by showing them the detail it covers for any specific job.
Old Nov 26, 2016 | 03:20 PM
BryanM.'s Avatar
Resident Gearhead
Old Nov 27, 2016 | 11:20 AM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Your post was substantially more useful than "2 hours and pull the dash".
There seems to be quite range of talent on here...
Old Nov 27, 2016 | 01:38 PM
mk378's Avatar
Removing both front seats (4 bolts and maybe a wire plug each) will make access to the dash area a lot easier. Yes you unbolt the column (unplug all wires, remove 4 bolts) and lower it down. It is a good idea to render the airbag safe before doing that. Please read the airbag directions in the FSM and follow exactly.
Old Nov 27, 2016 | 04:54 PM
fcm's Avatar
fcm
Old Fart
2 hrs, yea 4 guys with years of experience and air tools.
As mentioned set aside a week end, I have done a few of them, I have the tools but still takes me a full day.
I never pull the seats although it can't hurt, the dash pull by itself is easy, pretty much plug and play. 94
junior walker
Mar 10, 2020 03:32 PM
B_Swapped93
Nov 19, 2013 03:34 AM
TranferMePlease
Honda Civic (2006 - 2015)
Aug 14, 2010 07:52 PM
Josue
Oct 21, 2005 07:43 AM
