Please help! Acceleration prob!
Old Nov 21, 2016 | 09:44 PM
Tegboii's Avatar
Default Please help! Acceleration prob!
So I've take the throttle body and intake manifold off to clean which before that my teg was running just fine and now that I've put everything back when I press on the pedal to Accelerate the car cuts off (turns off) it's hard to explain but it just drops rpm to 0 and then no power I've also replaced my IAC with a cleaner one and I've checked that all vacuum hoes are connected correctly and I hooked the lines to the throttle body to open and close it so I'm kinda lost and need help asap. Please, thank you
Old Nov 22, 2016 | 12:04 AM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: Please help! Acceleration prob!
Check to make sure your MAP and TPS are connected properly. They can get switched around.
Are you triggering any CEL codes?
Old Nov 22, 2016 | 01:02 PM
Tegboii's Avatar
Yah they are connected correctly should I get a new tps? The check engine light did come on but only before I changed the IAC then it turned of
Old Nov 30, 2016 | 12:28 AM
wunfstgsr's Avatar
Loved
Community Favorite
Swap the plugs and see if it gets fixed like he said they fit eachother and sometimes get switched by accident when you plug them back in.
dmossdrum91
Sep 20, 2015 02:16 PM
alvinoolivas
10
Sep 10, 2010 09:35 AM
Kovatch EG
Jul 17, 2006 11:47 AM
Mr. JDM-GSR
Oct 30, 2005 01:47 PM
CleenSi
Nov 4, 2003 05:35 PM
