F20b swap into 01 SH won't start!
Old Nov 18, 2016 | 06:07 PM
ngengok99's Avatar
Default F20b swap into 01 SH won't start!
Hi guys! So I just finished F20b swap into my 01 SH. Wirings are correct, compression good, fuel good, ground is checked, I tried h22a4 distributor direct connection and td61u distributor with Prelude obd2 to obd1 distributor wire adaptor. I have a chipped p28 with F20b basemap. I am using F20b throttle body(map sensor), IM lower plenum is f20b, IM upper plenum h22, injectors F20b, fuel rail h22, egr h22, fuel pressure regulator h22, iacv h22.
It cranks but no start. I seem like I'm not getting spark.
Old Dec 9, 2016 | 09:29 AM
PreludeS2000's Avatar
Default Re: F20b swap into 01 SH won't start!
Hi
The distributor that you used, is it a good known one? And also there can be a difference between the timing of the spark.
Old Dec 12, 2016 | 03:44 AM
ngengok99's Avatar
Originally Posted by PreludeS2000
Hi
Its working good so far. This was an alternative to a overpriced oem or used oem. It's lifetime warranty so that's a bonus. Timing is adjustable.
Old Dec 17, 2016 | 08:07 PM
nus_dogg's Avatar
Got it running or no?
Old Dec 19, 2016 | 04:43 AM
ngengok99's Avatar
It was the rywire obd2 to obd1 dizzy harness. Wires were not pinned correctly. Posted it on HONDA PRELUDE fb page and someone had the issue before. Lol who would've known.
Speedfiend97LX
Jun 2, 2011 12:41 PM
JohnD1079
Canada (Sales)
Jan 22, 2009 12:39 PM
powerofdreams8
Sep 26, 2007 07:45 AM
turtleman321
Mar 4, 2007 06:07 AM
