Water Outlet - Use Liquid Gasket?
Old Nov 17, 2016 | 02:46 PM
94 Civic Si's Avatar
Premium Member
Loved
Community Favorite
Default Water Outlet - Use Liquid Gasket?
B18C1 (1996) - the "water outlet" from the cylinder head to the upper radiator hose - is there liquid gasket between this piece and the cylinder head?
I cannot find mention of installing this on the head in the FSM. Online parts stores do not show a gasket to be used.
# 6 in the image below.
Thank you!
Old Nov 17, 2016 | 10:43 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Water Outlet - Use Liquid Gasket?
I suspect it's not in the FSM as it's put on at the factory and not expected to ever be removed.
I would personally use Loctite 30558 as I know the pressure rating of it is extreme and can more than adequately handle it. It's designed for steam boilers and the like. And it's resistant to most shop fluids. It's susceptible to alcohol so fuel is one thing it's not good for. Or if you don't trust the idea of a non FSM high temp gasket maker then I would say use Permatex "The Right Stuff" as it's the anaerobic flange sealer Honda uses for things like the oil pump. It's designed for machined surfaces that mate together such as that pipe fitting to the head.
I know others will stick with the religious use of "hondabond".
I also use the loctite 30558 for my exhaust joint gaskets after the catalytic converter as I know they don't surpass 600F at the flanges.
Old Nov 18, 2016 | 11:12 AM
Premium Member
Loved
Community Favorite
Thank you. The machine shop removed the water outlet when the head went in for valve job, I was surprised...
Old Nov 18, 2016 | 10:44 PM
bks84's Avatar
Loved
i typically use ultra grey on this.
Old Dec 2, 2016 | 09:53 AM
Premium Member
Loved
Community Favorite
I actually came across reference to the "water outlet cover" in the FSM under water pump!
Yes, they recommend liquid gasket. Glad I found it...
Old Dec 2, 2016 | 09:55 AM
Premium Member
Loved
Community Favorite
Thank you!
Old Dec 2, 2016 | 10:51 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Originally Posted by 94 Civic Si
Thank you!
Permatex: Right Stuff.
Best multi use sealant on the market,IMO(Most OEM sealants are a variation,or exactly the same formula)
Old Dec 20, 2016 | 09:16 AM
Premium Member
Loved
Community Favorite
Looks like ~$20: Permatex the Right Stuff 85144 - Gasket Maker | O'Reilly Auto Parts
Old Dec 20, 2016 | 10:57 AM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Yup.
mulin
Nov 3, 2004 09:25 PM
CrazyKoreanCrx
Aug 23, 2004 01:55 PM
92civic2004
May 7, 2004 03:00 PM
havok hybrid
Feb 13, 2003 06:47 PM
94gsr
Sep 12, 2002 11:37 AM
