99 Civic won't crank
Old Nov 14, 2016 | 05:13 PM
Gwells's Avatar
Default 99 Civic won't crank
I have been reading various threads re: no start
Its a 1999 Civic DX, starter clicks once when key is turned, does not turn over. Dash lights stay on the entire time, headlights dim but only very slightly.
Battery reads 12.6 V. Tried tapping the starter to no avail. Push starts just fine. Where do I go next?
Old Nov 14, 2016 | 05:28 PM
civic402lx's Avatar
Default re: 99 Civic won't crank
Have your battery and starter tested at the auto part store. You can remove both and take it in..
Old Nov 15, 2016 | 05:27 AM
DumpdEJ6's Avatar
I like the tuna here
Make sure the one spade connector that goes to the starter solenoid is firmly attached, if it's loose it will not start even when tapping the starter.
Old Nov 16, 2016 | 07:44 AM
Former User's Avatar
Auto or manual transmission? If the latter, check whether the rubber stopper at the top of the clutch pedal has fallen out.
Old Oct 30, 2017 | 02:29 PM
cody ellis's Avatar
Icon4 Re: 99 Civic won't crank
Did you ever figure this out? mine just started this today, was driving it at lunch , then 3 hrs later , it won’t start. same description as yours just a 02 Civic EX Automatic
Old Oct 30, 2017 | 04:12 PM
tamboo's Avatar
10 Year Member
Default Re: 99 Civic won't crank
could be time for a solenoid rebuild kit. inspect your contacts.
How to: rebuild your honda starter - Carolina Hondas
https://www.ebay.com/itm/DENSO-START...9Z2CQo&vxp=mtr
rayrayx11
Oct 21, 2013 06:18 PM
DriveSlowHomie
Jan 26, 2010 10:31 PM
PhilMac23
Aug 21, 2009 10:05 AM
94turbo
11
Jul 3, 2009 05:02 AM
allsho
Aug 5, 2008 04:30 PM
