Car won't start!! Oil light??
my 94 civic d15b7 won't start doesn't even crank just has the oil light and srs on the dash also the headlights,radio or Windows don't work but the hazards work...I don't know what the problem is I'm stuck at work
Dude you have electrical problems you had best listen to 402lx. Don't be a dick none of us are paid to help you. Boy with that attitude I'd get nowhere in life.
Gotcha. Gotta admire someone who gets right to the point. It's your VTEC solenoid, the cross-hatching is likely worn inside the solenoid so you need to disassemble it and hone the solenoid piston disc with a honing stone. 400 grit sandpaper also works in a pinch. Make sure the cross-hatching is fully referenced to the bevel point around the counter-shaft girdle or you'll have shaft flutter at lower RPMs.
SkyLinER
23
Aug 3, 2004 10:45 PM
