Compression test results are in! Are these numbers not extremely low?
Old Nov 13, 2016 | 03:15 PM
Vtec04's Avatar
Default Compression test results are in! Are these numbers not extremely low?
I just did a compression test on my 05 Civic with a D17a2 engine after replacing my head gasket. I tested each cylinder with the engine fully warm, all spark plugs removed, fuel injectors unplugged, throttle fully open and cranking for 8-10 seconds on each cylinder. Cyl 1 had 115, Cyl 2 had 120, Cyl 3 had 120 and Cyl 4 had 115. Is this why my engine feels so tired? It burns 1 quart of oil a week. It still runs smooth, but has low power at full throttle and has low torque on hills. Fuel efficiency is also not very good. So my question is should I replace my rings? I would rather not pull the head again, but I will do whatever it takes to get my baby healthy again. That is all it could be, isn't it? Thank you for your help.
Old Nov 13, 2016 | 05:17 PM
v4lu3s's Avatar
RTFM
Default Re: Compression test results are in! Are these numbers not extremely low?
Did you also run a wet compression test to see how much it went up with a bit of oil in the cylinders? It does seem though that with the other symptoms you have a worn engine.
Old Nov 14, 2016 | 05:48 AM
Vtec04's Avatar
My girlfriend overheated it to the point of blowing the head gasket and she said "the motor was pinging and losing power. It sounded like someone tapping on the motor with a hammer. I was 20 miles from home so I just went straight home..." Could that damage the rings?
platoonsmoke1
10
Dec 9, 2014 10:11 AM
mhewitt
32
Jul 11, 2011 09:23 AM
zhan28
Feb 23, 2008 07:19 AM
eg crunkmonster
Mar 31, 2003 08:29 AM
thao4life
Oct 8, 2002 03:46 PM
