Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
Help Identifying Source of Power Steering Leak!
Old Nov 12, 2016 | 11:45 PM
nexusRawr's Avatar
Icon5 Help Identifying Source of Power Steering Leak!
I've been having problems of awful noises coming from the power steering pump as well as always refilling it. Believe the pump itself is just fine, there are a couple of places where it seems to be leaking and I just want yall's two cents since I'm new working on cars. I think it is the high pressure hose (top one) that is causing everything. Would you guys recommend a full pump replacement or getting a new gasket and testing it? I've included some pictures, any feedback is greatly appreciated, Thanks!
Old Nov 13, 2016 | 08:23 AM
TyGuy88's Avatar
Default Re: Help Identifying Source of Power Steering Leak!
You may be leaking from the p/s rack seals. Many times the fluid leaks into and fills up the rubber boots without leaking visibly. Some folks pull the boot back to check, others poke a tiny hole in the bottom of the boot to see if fluid is trapped inside. If it is, the rack will either need replaced or rebuilt.
Old Nov 14, 2016 | 06:22 AM
speedlever's Avatar
An easy thing to do (and eliminate) is to replace the o-ring on the inlet side. With any luck, that will fix your issue.
DIY Power Steering Pump O-Ring TSB - Drive Accord Honda Forums
Zigory
Honda Civic (2001 - 2005)
Apr 1, 2019 08:21 AM
dcarey
Jun 10, 2017 08:17 AM
Nicks95GSR
Jan 8, 2007 10:49 PM
nitroaccord105
Nov 9, 2006 09:21 AM
fackyou
Aug 6, 2006 01:29 PM
