96-00 Civic Coupe Window Regulator bolt pattern
Old Nov 10, 2016 | 12:25 PM
t_can's Avatar
Default 96-00 Civic Coupe Window Regulator bolt pattern
Can someone confirm the bolt pattern that's supposed to exist on the motor for coupe window regulators. I ordered an aftermarket regulator without motor intending to swap the motor over, but the bolt pattern on the motor is different than the regulator so they don't bolt up. Before I go making angry phone calls, I figured I would check to see how it's supposed to be. Maybe it's been replaced previously....
My motor is a 3 bolt pattern, the regulator I bought has 4 bolts.
Old Nov 10, 2016 | 02:10 PM
Former User's Avatar
Default Re: 96-00 Civic Coupe Window Regulator bolt pattern
Doesn't sound like the right regulator, but posting pics may help.
Old Nov 10, 2016 | 03:01 PM
t_can's Avatar
This is the regulator I bought. You can see the 4 holes.
This is the motor I have. You can see it's held in with only 3 bolts/screws.
Old Nov 11, 2016 | 09:35 AM
x.l.r.8's Avatar
Am I crazy because they look like different sides for a start. Your motor pic totally occludes the regulator to show where the 3rd bolt is, but it still looks like a close, but not close enough to be the correct one
Old Nov 11, 2016 | 02:42 PM
mk378's Avatar
It looks like they just don't use one of the holes in the back end. Did you actually try to fit the motor on?
And yes if those are your actual parts, you have a bigger problem of right side vs. left side.
Old Apr 9, 2017 | 12:50 PM
t_can's Avatar
Here's the answer. 3 bolt is not compatible with 4 bolt. 4 bolt is not compatible with 3 bolt. It's an aftermarket thing. Order the regulator with motor to avoid problems. I think my problem was the regulator had been previously replaced with an aftermarket one, and so when I bought the OE style motor, it wouldn't wouldn't bolt up.
MakeshiftJPN
May 11, 2012 03:03 AM
cypressink
Welding / Fabrication
25
Dec 17, 2009 08:40 PM
DARKTEG_
Oct 9, 2006 08:32 PM
Nextelbuddy
19
May 27, 2003 12:25 PM
MugenGTR
Feb 18, 2002 07:18 AM
