Keep B20b or swap for B18c
So I bought a Integra gsr with a b20b swap already done to it however I ended up blowing that engine up due to my cluster not working but I was trying to see what you guys think would be best cause I've heard the b18c's are much better than the B20. My goal is to have a powerful naturally aspirated and that's gunna be able to handle turbo when I get around to that part of my project. When I'm done with everything I'm trying to do I'm shooting for a Integra that will get me close to 500hp if not more! If anyone can help me out I was told to look at the b18c motors but idk exactly which way I should go for all the different ones. Also if any of you guys have an input as far as other ideas that I could bump up my HP please let me know! My Integra is a 1994 as well
So what would your opinion be on for a future turbo? Maybe even as far as going twin turbo? And I do have money but I'm also not looking to spend more than I have to.
And you need to put in a whole lot of hours researching this before you even start selecting parts. The easy way is to pay somebody to do it, but there is more than enough information on these forums to do it yourself for a whole lot less money. For 500HP you have a lot of decisions to make: what block, sleeved or not, what pistons, what rods, what C/R, what head, what valvetrain, what exhaust manifold, what intake, what turbo, what transmission, what transmission modifications, what differential, what tires, how you plan on actually using 500HP to the front wheels without spinning through 3rd gear, what engine management, standalone or piggyback, etc. It's not an easy or cheap process either way, I looked into a turbocharger and ultimately decided that I'd rather just buy another car that drives the correct set of wheels.
If you're 100% set on turbocharging your Integra, I would drop a cheap $350 JDM low comp B20 in there while you build your engine on a stand. And afterwards, I hope you have another car because I guarantee you will have lots of problems to work out once you install the new motor.
So what I still need to do is same as I should of from start.
Buy a b18c from a good source and rebuild the motor for what you want in it(valves pistons or whatever you want. Then make sure you have everything else you want on it (intake injectors dizzy ) then get your turbo kit and turbo. Or but turbo first and kit fit everything and rebuild the motor. Or just go to a good shop with lots of turbo Honda and see what they say.
