97 accord 4cyl non vtec no injector pulse after head gasket change
Old Nov 9, 2016 | 09:22 AM
Jamespatrickdj's Avatar
Default 97 accord 4cyl non vtec no injector pulse after head gasket change
Hey guys so i recently blew my heads and swapped the gasket.put it all back together and have been chasing electrical probs since. started with no spark and no injector pulse but it turned out i didnt have the crank sensor plugged in all the way. now i have full spark and my cel is not flashing. but stil no injector pulse. i have 12v to one side of the injector but no ground pulse on the other. i also have plenty of fuel pressure. and am pretty positive my timing is right. what could cause only injector pulse to fail? the ecu ground is attached.
Old Nov 10, 2016 | 11:10 AM
holmesnmanny's Avatar
Default Re: 97 accord 4cyl non vtec no injector pulse after head gasket change
Check all your fuses, both in the engine bay and the driver side kick panel.
Old Nov 10, 2016 | 11:57 AM
I worked it out. in the Haynes manual the distributor/cylinder diagram has no orientation marks so i read it wrong. had all my plug wires in the right order but rotated 180°.which would have been fairly easy to diagnose but in combination with the fact that i must have taken the dist off on the exhaust tdc on accident means i marked it 180° wrong and put it back wrong. so in theory if the plug wires are 180° around as well as the dist rotor it should run right? i think the cyp sensor was cancelling the injector pulse while silently calling me an idiot. no cel which suprises me. the only reason i figured it out is i found a diagram for the plug wires with an orientation mark and thought "i think i have mine on different..."
Old Nov 10, 2016 | 03:10 PM
No, because the engine timing is going to be off in relation.
NevinJoe
Sep 17, 2025 12:50 PM
davidbrookstone
Nov 11, 2011 11:38 AM
bcp7272
Feb 6, 2011 08:30 AM
mindslayer84
Nov 5, 2010 12:59 PM
100whplusperliter
Oct 11, 2003 08:18 PM
