Honda CR-V & Element 2WD & 4WD Element & CR-V
97-01 CR-V clock issue fixed !!!
Old Nov 6, 2016 | 10:04 AM
M-benz's Avatar
Default 97-01 CR-V clock issue fixed !!!
Photos said it all
Old Nov 6, 2016 | 08:36 PM
Highny's Avatar
Default Re: 97-01 CR-V clock issue fixed !!!
I did the same repair. I added solder to all the resister except one under the display. MY solder iron a bit too big to reach. The odd thing is, after the repair, whenever I start my car, it would come on. Few seconds later it would cut off. Around 3-5 mins later it would come back on and stay on. Not sure if it's the cause of that one solder joint under the display or a capacity gone bad. Have you experience something similar? If so, any idea how I could fix it?
Old Nov 7, 2016 | 04:34 AM
M-benz's Avatar
I have not experienced any of that ...mine works perfect
Old Sep 14, 2020 | 03:47 AM
SuperMario99's Avatar
Good job friend, I did it and the clock started to blink again. Suggestion : do not use more than 300° Celsius on the small resistor, it can be burned. I have checked it on the multimeter : 30 Ohm and on the PCB 1W tolerance....so hard to match with one on my desk. Anyway...thanks a lot.
jmcook79
10
Jul 27, 2013 06:41 PM
LeaveMeAloneClifford
Jun 8, 2008 06:27 PM
crookedletterd
Jul 9, 2001 07:49 PM
