Suspension & Brakes Theory, alignment, spring rates....
Replacing Captive Nut - Compensator Arm
Old Nov 5, 2016 | 07:12 PM
Evan214's Avatar
Default Replacing Captive Nut - Compensator Arm
The captive nut assembly broke inside the body of my car, long story short, i got the remains cleaned up and the surface is nice and flat on the inside. Can I just use a washer and nut with some blue lock-tight, rather then welding in a new captive nut assembly? Grade 5 or 8 Nut? Got the OEM bolts from Honda.
Thanks
Old Nov 6, 2016 | 07:42 PM
98civdx's Avatar
Master Detailer
Default Re: Replacing Captive Nut - Compensator Arm
You are much better off having it welded.
blue loctitie would likely hold it just fine, but the amount of work it takes to get the nut... don't take chances, and weld. IMO
OmgDelSol
Apr 15, 2014 08:29 AM
Silent_Destruct
Apr 26, 2006 05:08 PM
the soL that could
Suspension & Brakes
16
Apr 8, 2006 02:03 AM
Wes V
Welding / Fabrication
18
Apr 12, 2005 01:25 PM
Dseriespower
10
Dec 7, 2003 08:09 PM
