Can't figure it out
Old Nov 4, 2016 | 08:10 AM
Wats wrong's Avatar
Default Can't figure it out
I can't figure out what's wrong with my 95 Honda accord. When I go from stop it's barely moving until I get over 2rpms then it will speed up but as soon as it switches gears it does it again, sometimes my tact bounces around or it'll just drop. Ive changed the starter, spark plugs, distributor, had the fuel line checked, and it's still doing the same thing. I bought a new tps but I don't want to install it if that's not going to fix the problom. Can somebody, anybody please give ur input thanks
Old Nov 5, 2016 | 06:55 PM
jackdog1's Avatar
Default Re: Can't figure it out
If you changed all that trying to fix it, you shouldn't be working on your own car.
The problem is obvious; you have a bad speed sensor somewhere (most likely the transmission input shaft sensor). The transmission bases when to shift and engage lockup based on rpms and pressure: so if the sensor is bad, it'll give you those symptoms. That's why your tach is acting erratically.
Any CEL codes?
Old Mar 10, 2017 | 08:40 PM
amerc's Avatar
Check your ground connections .. a couple of places to check where ground wires are connected to your chassis. Do you have crank / start issues ? If so check grounding first.
Mikeao23
Jul 11, 2017 07:19 PM
Closetgeek
Dec 9, 2015 04:45 PM
killa_kraze420
Apr 6, 2014 03:52 PM
erl_loggins
Aug 18, 2013 01:13 PM
h23acc0rd
Jun 2, 2007 05:32 AM
