Automatic dash harness in a manual
Old Nov 3, 2016 | 02:39 AM
lolv8s's Avatar
10 Year Member
Default Automatic dash harness in a manual
okay so my dash harness is cut up pretty bad and I'm replacing it and the driver side too. I need the wires to the lights and to the rad fans also because I don't have them lol. Only thing is it's a manual and I've found an automatic. I already have the driver side (usdm). Is there no way this will work?
Old Nov 3, 2016 | 05:00 AM
tony_2018's Avatar
Fish Twig
Default Re: Automatic dash harness in a manual
There are certain differences, you'll just have to bypass the automatic shifter.
Old Nov 3, 2016 | 05:32 AM
lolv8s's Avatar
10 Year Member
Is there a forum you could give me a link to that would tell me how to do this? I don't have the wiring under the fuse box yet. I can go to another junkyard and try to find that. But I'm the end the wiring from an auto car could work? Thanks . Just need a link if it will work
Old Nov 3, 2016 | 07:55 AM
civic-steve-94's Avatar
Vehicle info is needed to tell you how to bypass the park neutral switch ( year,make,model). All I did when I swapped the automatic harness into my eg was solder together the wires for the park neutral switch.
Old Nov 3, 2016 | 08:05 AM
lolv8s's Avatar
10 Year Member
96 Integra LS but I swapped in a b18a1 that I built.
Old Nov 4, 2016 | 01:40 AM
bks84's Avatar
Loved
the harness that runs inside the dash board? that plugs into your fuse box, radio, heater, etc...
or the harness that runs along the firewall under the carpet? that plugs into the fuse box, and runs outside the car to the headlights, etc?
Old Nov 4, 2016 | 09:35 AM
lolv8s's Avatar
10 Year Member
the harness that runs along the firewall. I cut it at the part that runs behind the dash. I'll have to solder it. But I have the rest.
Old Nov 5, 2016 | 02:42 AM
tony_2018's Avatar
Fish Twig
I haven't seen a forum that details what the differences are, you are welcome to download the fsm on the differences to formulate your answers.
Old Nov 5, 2016 | 06:35 PM
v4lu3s's Avatar
RTFM
you will need to figure it out with a bunch of wiring diagrams. there is also a good chance that you will need a matching automatic engine harness for the engine harness to plug up unless you repin all of that too.
Old Nov 6, 2016 | 12:22 PM
lolv8s's Avatar
10 Year Member
that's just the part that would plug into the bottom of the fuse box? Can anybody add to that?
Old Sep 15, 2021 | 08:22 PM
tce336's Avatar
I’m trying to switch the one inside my dash for power windows, would it matter which one then ?
jahmesz
Jun 9, 2016 10:57 AM
slayersluck
May 15, 2014 06:26 AM
Cap'N Chronic
Jul 14, 2012 03:01 AM
civic-steve-94
11
Oct 31, 2011 06:51 PM
95 civic b16
Feb 4, 2009 07:28 PM
