Adding Keyless Entry to 95 Del Sol Si
Old Nov 2, 2016 | 09:32 AM
sicilian68's Avatar
10 Year Member
Icon5 Adding Keyless Entry to 95 Del Sol Si
Hello to all,
I have a 1995 Honda Del Sol Si. I recently installed a Bulldog remote start system and would also like to connect the keyless entry. The car has power locks but I am finding it VERY difficult to access the suggested wiring harness in the drivers kick panel to make the wiring connections. Has anyone successfully installed keyless entry? If so, please pass on your suggestions/experience for making the wire connections. Thanks in advance.
Old Nov 2, 2016 | 09:35 AM
tony_2018's Avatar
Fish Twig
Default re: Adding Keyless Entry to 95 Del Sol Si
If the alarm is the latest it should have the option of keyless entry, you'll need to get both the diagram to the alarm and to the del sol.
Old Nov 2, 2016 | 10:07 AM
sicilian68's Avatar
10 Year Member
Default Re: Adding Keyless Entry to 95 Del Sol Si
Thank you for the input. I have the wiring diagrams of both the Del Sol and the keyless entry. That isn't the problem. The problem is accessing the needed wires to make the connections. I was hoping someone has done this before and knew of a quick, easy way to make the wire connections.
Old Nov 2, 2016 | 10:14 AM
Former User's Avatar
It may help to remove the front seat and the lower dash panels on the driver's side, in addition to the kick panel.
More details would also help. For example, what types of connections do you need/want to make? Post pictures of wires and connectors of interest.
Old Nov 2, 2016 | 10:22 AM
tony_2018's Avatar
Fish Twig
Does the diagram for the del sol not tell you where to look and test for the wires? Stop trying to find some quick way to get things to work or you'll end up shorting something out.
Old Nov 2, 2016 | 10:37 AM
sicilian68's Avatar
10 Year Member
LOL. Ok, after the last post please let me point out that I am inquiring to people that have done this before. If anyone has installed keyless entry they know what wires, etc.., I need access and am referring to. I am looking for suggestions from people who may have accessed the wires at a different location or have experience in the project. Input is appreciated, but only if it is helpful. If you have not taken on the task before, please don't post. It isn't helpful.
Old Nov 2, 2016 | 12:17 PM
Stop bitching. You're inquiring to whomever is willing to volunteer their valuable time. A simple "thank you for your input" will suffice. If you want to make demands, pay a mechanic to do the work for you.
Please read the forum Rules sticky before you make any additional posts.
cevax
Jul 18, 2011 09:20 AM
Kellindil
May 2, 2005 05:27 PM
Del Souless
Audio / Security / Video
Apr 5, 2005 12:22 PM
Del Souless
Apr 1, 2005 08:02 AM
