95 Civic - reverse lights and transmission bolt torque specs
What's this bolt called so i can know its torque specs
Its a 5 speed manual vtec 95 civic.
Are these transmissions to engine bolts OR transmission case to flywheel housing bolts?
re: 95 Civic - reverse lights and transmission bolt torque specs
Transmission housing bolts or Transmission mounting bolts
This is a question is easily answered if you have the 92-95 Civic service manual, which can be downloaded for free. Do some Google searches.
Re: Reverse lights connector on 95 civic ex
Match the wire colors inside the tubing in your hand?
Otherwise, randomly choose one configuration. If it works, you're good to go. If not, switch the wires.
NorCal_ej1
01-04-2014 11:51 AM
instructor74
07-12-2007 04:17 PM
