B20z2 problems
Old Nov 2, 2016 | 05:59 AM
Kouki_smurf's Avatar
Default B20z2 problems
hi guys I'm new to this forum and figured I'd try it out, my b20z2 swapped eg sedan is having a problem, once you turn it on it just revs by it self to 3-4K Rmps and goes back down to idle and then back to 3-4k Rmps and doesn't stop I've tried changing the throttle body gasket but it still does it, does anybody know what it could be?
Old Nov 2, 2016 | 06:05 AM
eh2_Trav's Avatar
Default Re: B20z2 problems
1. Check for any vacuum leaks
2. Unbolt and clean your IACV from back of manifold.
I would start there. Good luck. If you don't know the vacuum diagram or where the IACV is, google and youtube will help you figure it out..
Old Nov 2, 2016 | 06:09 AM
Alright thanks I'll try that
Old Nov 2, 2016 | 06:15 AM
eh2_Trav's Avatar
Let us know if that solves your problem. Sounds like you have a "hunting Idle" . There are other reasons it could be idling bad such as an air bubble in the coolant system. We are all assuming you haven't done any kind of work on the car and these symptoms have just surfaced.
Old Nov 2, 2016 | 07:29 AM
Former User's Avatar
Sounds like a massive vacuum or intake air leak.
chope045
Oct 24, 2011 04:12 PM
Excusetoboost
Sep 1, 2011 07:40 PM
asianrepnsb
12
Mar 8, 2008 12:26 PM
rtiadnoh
Feb 15, 2004 12:41 PM
quikyEG
Feb 27, 2003 09:07 PM
