timing belt tension
Old Oct 31, 2016 | 08:26 PM
1990IntegraLS's Avatar
Default timing belt tension
I just did the water pump and timing belt. Every thing went fine, but I've seen lots of people say to push the tensioner a bit before tightening. This is a b18a1 with 170k miles.
I know the standard procedure is just to let the spring work.....but I'd like to know if there's a more general measurement. I've seen some people say you should be able to rotate the belt a certain amount. I did push the tensioner just a little while tightening....and I can hear just a little difference now, then before I did the job. A little bit of wherring, maybe. Put in a Gates Racing belt. I also change all the accessory belts to.
Opinions?
Thanks.
Old Nov 1, 2016 | 03:13 PM
fcm's Avatar
fcm
Old Fart
Default Re: timing belt tension
Timing Belt and Water Pump Replacement on a G3 Teg - Team Integra Forums - Team Integra 94
1990IntegraLS
Dec 17, 2016 04:30 PM
ginahoy
Sep 1, 2014 05:02 AM
honda94accord
Apr 10, 2007 05:39 AM
BlackGser
Apr 27, 2005 11:00 AM
obd2gsr
Dec 21, 2002 08:53 PM
