Lift, Minor Maintenance, and Compression Test
I returned from deployment a while ago and spent some money and time in my V. I have an auto 2001 EX and here's what I've done recently:
Iron Man 1.5" lift springs with Tokico struts
215/70R15 tires
Replaced trailing arm bushing and a couple motor mounts
Flushed/refilled ALL fluids
Cleaned injectors
Cleaned IAC valve
Replaced PCV valve
Installed short RAM intake
Replaced stock muffler with knock-off muffler
Cleaned throttle body, intake, and air filter
Replaced fuel filter
Adjusted valve lash
New plugs and wires
Next up:
Re-check valve lash, just to be sure
Clean MAF
New distributor cap and rotor
Before doing all the maintenance but after the RAM/muffler, the car idled rough and towards the end, died at idle, especially when pointed uphill. MPG was around 17; 19 on some days
Cons:
I didn't notice any power or MPG difference with the short RAM and muffler (I got them at the same time, before all the maintenance) They make a great sound but I might go back to the stock set up
Didn't notice too much difference with the injector cleaning
After adjusting the valves, I now have a slight ticking sound coming from engine
Pros:
The lift looks great and with the trailing arm bushings and motor mounts, rides great, too. I had the tires put on before the lift (old tires were poo-poo, couldn't wait). When these wear out, I'll go slightly bigger; just enough to fill the wells but not look ridiculous or weigh the car down. I'm thinking something like 225/75
After replacing all the fluids, replacing the PCV and fuel filter, and cleaning the IAC, I noticed a slight power boost and MPG increased to 22/23 consistently
After adjusting the valves and replacing the plugs, I noticed a substantial power boost, a smoother idle, and an all-around more pleasant driving experience. I did notice a slight ticking sound immediately afterwards but I'm overall impressed the improvement. I'll re-check the valves tomorrow. This was my first time doing it so I'll dig back in and make sure everything is consistent before I do any more major work. While I was in there I noticed the timing might be a little off, so as soon as I can borrow a light gun, I'll check that. I haven't checked the MPG again but I assume I'll get another couple MPG increase.
Also, immediately after the valve adjustment, I felt like the idle was too fast. I read somewhere that it should idle at 750 rpms and my tach was reading around 1100. I was going to read up on doing a Idle Relearn Procedure but after about 50 miles, the idle calmed down to somewhere under 1000 and it feels more like it used to so I'll leave it alone for now.
I did a compression test tonight and here are the results:
Dry
189 179 175 179
Wet
200 196 192 196
I know it's a lot of effort and money for such an old, underpowered car, but she's awesome and fun to drive, especially now that she's got a little more umph
Any questions or suggestions, feel free to reply. Thanks.
215/70R15 tires
Cleaned injectors
Cleaned IAC valve
Replaced PCV valve
Adjusted valve lash
New plugs and wires
Next up:
Clean MAF
Cons:
Pros:
Dry
189 179 175 179
Wet
200 196 192 196
mrnorm
Apr 10, 2008 05:56 PM
