1996 Accord Replacement Ignition Coil is Too Fat
Old Oct 27, 2016 | 06:52 PM
darecare's Avatar
Default 1996 Accord Replacement Ignition Coil is Too Fat
I have a 1996 Honda Accord LX 4cyl, 2.2L, (F22B2). I need to replace the ignition coil.
The bad part is a TEC TC-19A - Honda part #30520-PT9-A02.
I ordered a part online and that matched the Honda part number. But when I tried to
install it it would not fit my mounting bracket. Turns out the new part has a fatter and
wider belly. So I returned it and ordered a different brand that (Spectra Premium Ignition
Coil C-633) per their online parts catalog. The belly of the Spectra part I received also
has a fatter/wider belly than me O.E. part - 2" vs. 2-3/8". So the
Spectra part Spectra part
does not
fit my mounting bracket either.
Does anyone know what's going on?
Does anyone know where I can get the correct replacement?
Do I need an updated mounting bracket?
Thanks.
Old Oct 27, 2016 | 08:45 PM
GhostAccord's Avatar
Default Re: 1996 Accord Replacement Ignition Coil is Too Fat
That is definitely the wrong part.
If you want to stick with the Spectra Premium coils you should be looking for Part # C-633
Old Oct 28, 2016 | 02:11 AM
holmesnmanny's Avatar
rockauto is really good at making sure they use the correct cross reference part numbers
raverx3m
Nov 30, 2013 05:19 PM
DAVE15401
Jun 25, 2007 07:56 AM
scrubachu
Sep 26, 2001 08:10 AM
