Coilovers too small for fork
Someone help me please I ordered a new set of coilover and went to install them and when I did the fork would not tighten up to the coilover why is that it's as if the fork is way to big or the coilover is way to small help please
I don't recall, but if you really have the correct dampers, and they are EG, then it's very likely you have DA/EF front forks. Not many forks in this chassis line. It's either too small, or too big. If your's is too big, then there is only 1 other fork to try lol. The EF/DA forks have an ID of 1.502" and the EG ones were 1.650".
Simplest way to put it
if coilovers fronts are too small in diameter to fit in your forks
then u have Ef/da fronts with eg/dc forks
if ur coilovers are too big and won't fit the forks
then u have eg/dc fronts with Ef/ da forks
so with that in mind
it looks to me from what you're deacribing
you have Ef/da fronts trying to slide into eg forks
go find a 88-91 civic/ idk year da but 89-93? Da parts car and grab the correct forks (should cost u $10-$30 bucks)
and voila
^this is for first post
u said front struts too small
youre second post regarding "skunk2"
that part like above said u probably gotten Ef/da spec
and are trying to put it onto eg forks so go find a 92-00/94-01 and grab front forks
also u need to be more specific
do u have front coilovers that are too small to fit the form
or do u have front coilovers that are too big to fit the fork
first post u say coilovers too small to fit fork
second post u say coilovers too big to fit fork
and voila
and voila
and voila
If they are smaller than the skunk 2, then you do not have a setup for the EG/DC2 chassis, you have a setup made for the EF/CRX/DA. Did my post not clearly explain this? I build coilovers for a living. Were all these post necessary for you to figure this out. It's clear you don't have the right product if your skunk2 indeed are larger, and fit into the fork just fine. Your answers is right in front of you, you don't have the right set of coilovers if those maxspeed are smaller lol.
B16A1-EF9
Sep 13, 2002 05:01 PM
