Hello Al! New here!
Old Oct 26, 2016 | 06:34 PM
LudemanX's Avatar
Default Hello Al! New here!
UNDER CONSTRUCTION! !
Hi all! I'm Shawn, 35 from New Brunswick Canada. This is my 96 prelude sr-v formula which I'm building into a auto x, circuit time attack, street fighter!! Body mods are functional for aero and have/are being customized to provide as much downforce as possible. Front and rear diffusers will be made when the time comes for them. I'll be building the h22a for boost with a 600hp goal but using a halltech elite ecu to run multiple tunes so I can keep the car versatile and usable for different situations.
Current modds:
Exterior: jdm aftermarket (unkown)front customized with Veilside supra lower valance center.
Siides fiberglass (unknown ) modded with supra Veilside lower valance outer edge wings.
Rear fiberglass (unkown ) modded to fit custom rear diffuser
Fiberglass (Vader? ) hood vented.
Carbon fiber trunk lid
Fenders/quarters being modded for wide body
Wheels (current junk with bald tires) lol. Going with 17×10 light weight with wide rubber.
Suspension tien street advanced coilovers
Bwr rear subframe brace
5th gen spindles and hubs
Energy polyurethane bushings
Brakes. Rear oem calipers with drilled and slotted rotors
Front upgrading to acura mdx dual piston
Performance. H22a
Clutchmaster 14lb flywheel
Stage 3 clutchmaster clutch w/sprung hub. (For now)
Type S 65mm tb
Cai with thermal wrap
Vibrant 4-2-1 stainless headder with heat wrap
High flow cat
Skunk2 megapower cat back (fabbing custom center exit duals)
Skunk2 pro2 intake drilled for direct port nitrous
Aem fuel rail and fpr
Interior. Semi gutted. Oem leather. (For now)
Probably forgetting a few things but so far that's about where I'm at with the build... will update as it comes togather
Cheers all!!
bluebird
Feb 4, 2011 03:57 PM
WeaKSouL
May 5, 2004 05:49 AM
Project X
Feb 1, 2004 07:03 PM
cre18
22
Sep 18, 2003 05:05 PM
