Is it possible to use Brian Crower Stage 2 NA cams in a turbo B18B?
Old Oct 21, 2016 | 07:34 AM
Ricerjack's Avatar
Default Is it possible to use Brian Crower Stage 2 NA cams in a turbo B18B?
So I have a set of bc stage 2 n/a cams for my b18b but I've decided to change the direction of my build from n/a to turbo , now the stage 2 n/a and f/I cams have the same ti retainer/valve spring kit , can I still use the n/a cams with a turbo setup (goals around to safety run around 15psi , hoping for around 300hp)
Build specs so far ,
stage 2 n/a cams
3angle valve job
crower ti retainer and valve spring kit
Specs of n/a cam:http://www.briancrower.com/makes/honda/cam_card/bc_0022.pdf
specs of f/I cam: http://www.briancrower.com/makes/honda/cam_card/bc_0021.pdf
Thanks for any help
Old Oct 21, 2016 | 07:39 AM
boosted94gsr's Avatar
Default re: Is it possible to use Brian Crower Stage 2 NA cams in a turbo B18B?
I used those cams in my old ls swapped hatch. Had good results with them. Made good power and had good drivability and idled like stock.
Old Oct 21, 2016 | 11:38 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Is it possible to use Brian Crower Stage 2 NA cams in a turbo B18B?
Yes, you sure can. They work well with a turbocharger.
Old Oct 21, 2016 | 11:44 AM
Here's a video of my hatch with those cams at the track on street tires. That thing definitely moved with those cams.
Old Oct 21, 2016 | 04:00 PM
Ricerjack's Avatar
https://youtu.be/vEsJ6bhFOfk
thanks man , I read up on your build on the video description, I was thinking about doing a pretty simular build
b18b1
arp headstuds (already have)
stage 2 bc n/a cams (already have)
bc valve spring and ti retainer kit
​​​​​​​3 angle valve job done on head
edelbrock victor x intake (but I found a cheap blox intake on kijiji as well , any suggestions on that) (I'm more leaning towards the victor x)
b16a Nippon pistons(already ordered in the mail)
ls rods
arp rod bolts (already have)
And I'll be honestly I haven't really researched turbo's too much so I haven't bought anything yet, any suggestions would be appreiceited , looking for atleast 325whp but the more the better , thanks boosted94!
Old Oct 21, 2016 | 04:10 PM
Ricerjack's Avatar
Also found a set of cheap Manley turbo tuff rods for cheap too, think I might get those soon
Old Oct 21, 2016 | 05:19 PM
b18b1
ls rods
Here is a link to my build thread. It pretty much covers everything I did start to finish. I think the victor x im is a little overkill for your power goal. Let me know if you have any specific questions. I'm always happy to help man.
https://honda-tech.com/forums/appear...build-3208172/
Old Oct 21, 2016 | 11:23 PM
TravisBiggie's Avatar
I literally thought about making the exact same post, but just read old messages from people saying it would be fine, the issue is overlap, but I was told I shouldn't have to adjust anything.
Also b18b1 setup with BC stage 2 n/a cams.
Old Oct 21, 2016 | 11:26 PM
sick setup, especially with BBG. How much power did it make at 22 psi? ~360whp?
I'm going for ~430whp. I have neptune RTP. I Want to set up BBG but I am clueless atm. I did buy a MAC solenoid, I'm not sure what else I'm missing.
Old Oct 22, 2016 | 01:50 AM
blackeg's Avatar
yes you can use those na cams on a boost motor. My friend did it with my old cams and i tuned it for him. thing made some power over 5000 rpm for what it was.
b18b1
ls rods
ok, do not use the victor x on that motor. sounds weird but the intake manifold you need is a p30. the blox can work too i would use a stock or 60 mm tb keep your velocities up.
b16 pistons in an ls motor give you probably more compression than you want. maybe use the nippon b series "vitara" turbo pistons which i think are the same compression as oem ls pistons. dont get too big of a turbo or too carried away. ls motors just dont have the workable rpm range to throw sizeable turbos on and have any kind of enjoyable powerband.
Old Oct 22, 2016 | 06:31 AM
Thanks! Based on my trap speed and weight it made about 385whp. I street tuned it on Neptune rtp so it was never on an actual dyno. I sold it a while back, kinda miss it tho lol.
I can help you setup bbg. PM if you want me to help you out.
Old Oct 25, 2016 | 03:58 AM
Ricerjack's Avatar
got the blox manifold (I found a cheap one near me) and why would I not want the 10:1 ratio of the b16 pistons rather than the stock 9:1? I don't mean to sound like an *** but I don't understand why people think turboing a low compression engine is that much safer than a high compression build , if it's tunedA right it should be just as reliable and put out better numbers no?
​​​​​​​http://www.team-integra.net/forum/16-forced-induction/2076-all-you-low-compression-******-read.html#/topics/2076?_k=5dms2c
Old Oct 25, 2016 | 05:54 AM
TheShodan's Avatar
Moderator
got the blox manifold (I found a cheap one near me) and why would I not want the 10:1 ratio of the b16 pistons rather than the stock 9:1? I don't mean to sound like an *** but I don't understand why people think tuning a low compression engine is that much safer than a high compression build , if it's tuned right it should be just as reliable and put out better numbers no?
​​​​​​​Not many (informed) people will argue with this here.
Old Oct 25, 2016 | 08:55 AM
Ricerjack's Avatar
anyone have any experience with the gtx425 kit? figure this would be a good kit for my setup with the possibility of growth , http://www.go-autoworks-store.com/gostxbabetuk.html
Old Oct 25, 2016 | 02:21 PM
Ricerjack's Avatar
GTX2867R
Fc_v8
Jul 26, 2010 03:15 AM
hatchback freek
Feb 2, 2010 06:48 PM
90Civtegra
Apr 24, 2009 05:29 AM
Kafelatte
Jan 21, 2007 05:17 PM
