Help identifying air filter from JDM ITR intake box
I bought a JDM ITR intake set which includes the arm, box and filter. Can someone help me in identifying what kind of filter this is? It looks very similar to the Spoon foam air cleaner but its red without the nose tip that snugs into airbox
The filter is pretty old. When I removed it there was red debris in the air box. The filter also sheds a bit when I brush my hand against it so I'm kind of weary of using it.
Thanks all.
Thanks all.
Not sure about the brand.. but junk it if its coning apart.
Buy a ct engineering filter, its foam and has a velocity stack, better buy compared to spoon
Yeah I don't think I'm going to use it if it's shedding..
Would you choose CT Engineering filter over K&N E-2427?
Ct engineering air filters are made by Uni. They also have a cleaning/re oiling kit for them, as does k&n.
I'll vouch for the CT Engineering filter. I'm actually getting rid of mine because I went with a different intake.
I used my CT filter for about two years, checked at every oil change and cleaned far less(I had a screen on my intake pipe behind the bumper), and it hasn't started falling apart yet. I highly recommend them.
All foam filters will degrade over time. You'll be fine for probably 5 years or more, but don't consider it a "lifetime" filter by any means. If you don't drive a lot or in dusty conditions, get the K&N as it will last a lot longer. I don't use K&N's in my daily, but for my weekend cars that's all I run.
Gargoyle
Jan 23, 2007 01:19 PM
rev limiter
13
May 1, 2005 11:53 PM
Ill
Sep 10, 2004 09:56 AM
