Glove Box Lock Screws
Hey, so I am missing one of the screws that hold the glove box lock assembly in place on my 97 GSR. I could not find the part # for those screws on any diagram, so I purchased a brand new lock assembly, assuming they would be included. Turns out it doesnt come with them...
Does anyone have any idea where I can get the screw and washer combo to fit this part? Am I just missing it on the diagram?
If you can zoom in closely looks like the screw you need is #33 in the diagram. If not just take you latch to your local hardware store and find a machine screw that is the right size.
1995 Acura INTEGRA HATCHBACK|
1995 Acura INTEGRA HATCHBACK GS-R SCREW-WASHER (4X12) - (90107-SE3-000) - Acura Parts Online
I actually thought it may be that one, but its nowhere near the latch on the diagram so I was hesitant to buy it.
At $2 I guess it cant hurt to just grab it when I make my next larger order and hope for the best.
Thanks!
What it almost looks in the diagram with the glove box being exploded as it is. If you were to just kinda put it back together it looks like latch would be right in that area. Its also looks to be facing in the correct direction I'm almost certain that's the only screw that faces that way in the glove box.
I know this was a couple of years ago, but did you ever confirm if #33 was indeed the screws and washers for the glove box lock? I assume you would have posted back if it didn't fit, but a definite confirmation would be appreciated.
I ended up buying part# 90107-SE3-000 (#33 in the links provided by Decatur Racer). I can confirm that this is definitely the correct screw for the glove box lock assembly. Be aware that there is only 1 screw per package, so if you want both you need to buy 2.
jondaurio
Feb 9, 2014 07:06 PM
Draiga1988
Jun 11, 2011 02:58 PM
Eibach95Civic
May 2, 2007 05:00 PM
