Car misfires,popping through the TB?
Old Nov 8, 2002 | 01:22 PM
94JadeAccord's Avatar
Default Car misfires,popping through the TB?
Greetings, i have a 94 accord lx and recently while i'm driving it, it misses while gaining speed. Under WOT between the shifts it sounds like it's popping or
backfiring under the hood. Changed the plugs,cap,and rotor so far. Still missing while gaining speed. Any suggestions. I'd like to figure this out without taking it to honda or other garage. Help!
Thanks...
jc
Old Nov 8, 2002 | 01:24 PM
Brandon's Avatar
Life is Suffering
Default Re: Car misfires,popping through the TB? (94JadeAccord)
Check that your exhaust isn't blocked.
Old Nov 8, 2002 | 01:42 PM
Default Re: Car misfires,popping through the TB? (Brandon)
Exhaust is fine.
Any other suggestions?!??!?
Thanks,
jc
Old Nov 8, 2002 | 01:49 PM
Stew Pidasso's Avatar
Maybe a bad Intake valve?
Old Nov 8, 2002 | 02:44 PM
Default Re: Car misfires,popping through the TB? (Stew Pidasso)
I guess it's possible,bad intake valve. If it was would the missfiring be all the time?
It idles smooth and at low speeds it seems to be ok. Is there a way to check out
the valves with out taking the head or valve cover off?
Thanks,
jc
Old Nov 8, 2002 | 03:36 PM
Desslok's Avatar
sounds like timing advance problem.
Old Nov 8, 2002 | 04:04 PM
Chiovnidca's Avatar
Leakdown test.
Old Nov 8, 2002 | 09:38 PM
When you shut the car off do you ever hear air/exhaust leak out of the intake? My car is missing like that too and I'm pretty sure it is the intake valves. I'm in the process of pulling the engine now and I'm gonna pull the head off as soon as it's out.
Old Nov 8, 2002 | 09:47 PM
89_LXi's Avatar
I dunno if this helps ya any, but mine was popping and misfiring pretty bad (only at idle though), and it turned out to be the distributor itself. Replaced it with a junkyard one and it completely fixed it. I have no idea how to check it though, especially those electronically controlled ones (mine I could hear the broken centrifugal advance springs rattling around in there). Just a thought....
Old Nov 8, 2002 | 11:06 PM
rollingCULTURE's Avatar
dude! my car does that!
what exactally are the intake valves?
Old Nov 9, 2002 | 04:49 PM
Default Re: Car misfires,popping through the TB? (rollingCULTURE)
This should help... http://www.howstuffworks.com/camshaft.htm
Old Nov 9, 2002 | 07:25 PM
Nick H's Avatar
New User
all cars do that with an aftermarket intake....mine does, so do all my car buddies...it's normal!
Old Nov 10, 2002 | 02:56 AM
Default Re: Car misfires,popping through the TB? (Nick H)
I'm not talking about a pop or a fart. I'm talking like a lot of air. My car even made a moaning sound out of the intake at one point. It was when I put that bad timing controller in and it screwed everything up.
Old Nov 11, 2002 | 12:29 AM
SPIRIT7623's Avatar
Default Re: Car misfires,popping through the TB? (89_LXi)
i had the same problem , got a used distributor ; problem fixed! my oil ring was leaking, i think the sensors ( tdc/crank/timing or somthing ) were jacked, wiring was open ; well it lasted for 12 years
Old Nov 11, 2002 | 08:28 AM
Default Re: Car misfires,popping through the TB? (SPIRIT7623)
I noticed that the distributor was making a ticking-knocking noise. Anyone have a used one laying around that they would part with? The salvage yards around here don't have any distributors forsale. That has to be the problem.
Thanks everyone for the advice.
jc
Old Nov 11, 2002 | 08:53 AM
I have one but it needs a new igniter.Make an offer...
Ryanwill86
Jan 14, 2009 06:04 PM
sick_dc2
Nov 22, 2008 01:33 AM
Marcg611
Aug 24, 2008 08:04 AM
02_Si_FTW
Jul 17, 2008 03:32 AM
