Broken drive belt while driving.
Old Oct 13, 2016 | 11:00 AM
Ener Won's Avatar
Default Broken drive belt while driving.
I replaced the alternator and two days later my drive belt broke while on th freeway. The car instantly shut off and will not turn back on. After I did some investigating remind battery Volts for at 9 and all my spark plugs were burnt. I change spark plugs replace the belt and still can't get it to start can anybody please tell me what I should look for or what steps to take to figure out what is wrong with the car
Old Oct 13, 2016 | 11:26 PM
holmesnmanny's Avatar
Default Re: Broken drive belt while driving.
Check all your fuses, especially the 90a fuse in the engine bay fuse box.
Old Oct 14, 2016 | 12:06 PM
fcm's Avatar
fcm
Old Fart
More info, MM&Y of car along with trim level, auto or manual and any mods?
Is engine turning over/cranking, [starter motor working] but engine just not firing up? 94
Old Oct 14, 2016 | 04:48 PM
1funryd's Avatar
What do you mean by drive belt?
The alternator belt?
Or the timing belt?
If its the timing belt, then it will not start because it bent valves and of course the timing belt drives the entire motor.
That means you have a big repair on your hands, new valves, new timing belt, water pump, and head work.
Old Oct 19, 2016 | 11:13 AM
radkins2's Avatar
I the alternator and two days later my belt broke while on th freeway. The car instantly shut off and will not turn back on. After I did some investigating remind battery Volts for at 9 and all my spark plugs were burnt. I change spark plugs replace the belt and still can't get it to start can anybody please tell me what I should look for or what steps to take to figure out what is wrong with the car
If your plugs are burn't something else must have happened. Are you getting spark? if not check here http://info.azmythmusictech.com/blog
sproket13
Aug 12, 2024 05:52 AM
Sam85
Honda CR-V & Element
Oct 27, 2010 01:19 PM
vw eater
Dec 3, 2006 12:03 PM
Jimmy
Jun 1, 2005 12:49 PM
skip.two
11
Dec 2, 2003 05:11 PM
