Cruise control only works ocassionally
Old Oct 12, 2016 | 11:35 AM
Nealva's Avatar
Default Cruise control only works ocassionally
I have a 1991 Accord LX coupe with automatic transmission.
I am having a problem with the cruise control in that it only works sometimes and seemingly less frequently.
When I turn the cruise control on using the button located on the left side of the dash the green light illuminates in the switch. When I press the Set button on the steering wheel the Cruise light on the instrument panel will illuminate but the speed control does not engage. The light will stay illuminated though.
I have tried putting my foot under the brake pedal when "setting" the speed but that makes no difference. I have also checked the electrical connector for the control module under the hood and checked all vacuum lines and all seems to be in working order.
Sometimes the speed/cruise control will work just fine.
Can someone here give me some troubleshooting tips to find the problem?
Old Oct 12, 2016 | 04:23 PM
tamboo's Avatar
10 Year Member
Default Re: Cruise control only works ocassionally
i'll pm you a link to the manual.
i just solved this problem. for me it was a loose connection at the 6 pin connector under the steering column.
zmss56
Honda Civic (2001 - 2005)
Dec 13, 2012 06:32 PM
The Cars
Dec 29, 2011 10:13 AM
gen4acclude
Feb 15, 2005 07:07 PM
Elvis1977
Jan 13, 2004 10:52 AM
