b16 crankcase vent system help
Old Oct 12, 2016 | 06:42 AM
1320london's Avatar
Default b16 crankcase vent system help
ive seen the catch can setups that block off the block vetn system on the back of the block. my question is can you just block off the block and not run a catch can without hurting anything.
Old Oct 12, 2016 | 02:33 PM
v4lu3s's Avatar
RTFM
Default Re: b16 crankcase vent system help
You could if you don't mind blowing out the front and rear main seals as having oil leaks.
Old Oct 12, 2016 | 03:52 PM
civic-steve-94's Avatar
What he getting at is the whole point is to vent positive crankcase pressure I.e. pcv. If the crankcase is not vented properly it will blow out oil seals and cause leaks.
yayizzil
Jun 7, 2009 01:24 PM
mo0cow
Oct 26, 2005 04:36 AM
@irborne
Feb 11, 2004 01:12 PM
highbrid
Oct 14, 2002 08:33 AM
