questions about D16Y7 head/D15B7 mini-me swap
Old Oct 10, 2016 | 10:09 PM
Jturpen569's Avatar
Default questions about D16Y7 head/D15B7 mini-me swap
Hello! I got a Y7 head i picked up from a friend parting out his D16 engine.
I have a D15b7 and was wondering about the following
1. What timing belt should i use? also can i use the y7 cam gear or should swap the gear from the b7 head to the Y7
2. Do I need the Y7 intake manifold or can i use the B7?
3. Can i use my B7 wiring harness?
4. Y7 head gasket is what to use as well?
5. Can i reuse the head studs from the Y7?
(dumb question but Im on a budget and anything is better than the b7 head on it now)
Thanks in advance! Any advice is also welcome
Old Oct 10, 2016 | 11:05 PM
eghatch9295's Avatar
Stancetard Hate Monger
Default re: questions about D16Y7 head/D15B7 mini-me swap
1. y7.z6/y8/y5 belt, b7 pump/tensioner
2.use your b7 manifolds, alternator, and distributor
3.yes, swapping all of your parts over makes this a plug and play affair
4.y7/z6/y8/y5, even the d15b(x) head gaskets will work. your call on MLS or graphite.
5.search b7/y8 mini me, same head bolt combo.
Old Oct 11, 2016 | 07:03 AM
Jturpen569's Avatar
Thank you answered what i needed!
Old Oct 11, 2016 | 08:27 AM
Jturpen569's Avatar
Wait one more thing, If i switched the cam gear from the b7 to the Y7 i can use the B7 timing belt cant I?
Old Oct 11, 2016 | 08:58 AM
no
Old Oct 11, 2016 | 11:41 AM
Jturpen569's Avatar
no
What combo do i use then, leave the Y7 camgear on the Y7 and use the Y7 timing belt?
Old Oct 11, 2016 | 05:44 PM
the simple solution is to buy an adjustable cam gear meant for a y7. you also need to remove the oil jet from the b7 block.
Old Feb 25, 2018 | 06:27 PM
Steve95DX's Avatar
Default Re: questions about D16Y7 head/D15B7 mini-me swap
what about Y8 intake manifold instead of the Y7?
Ocnaj
10
Jun 14, 2008 09:38 AM
mattcivic
12
Mar 20, 2007 04:19 PM
Harry_Randal
10
May 18, 2004 08:43 PM
sleepyhamsterlx
Jan 5, 2004 08:21 PM
