'98 Accord CF6 JDM - Brakes
Hi!
Just wondering if anyone here know the brake sizes for the CF6 wagon Accord F23A 2.3VTEC from Japan?
Brake discs front and rear
Is it 280mm front and 260mm rear?
I'm looking to buy a new caliper for the rear left, a friend said he thought it's the samme as the 97-01 Prelude. 9CLP14S would be the name of that caliper.
It looks the same, but I'm not 100% sure.
I'd do the measurements myself, but I don't have the car here for another 1 week
I am not familiar with that particular car, but if it were a car sold in the US, then the calipers should all interchange. Not necessarily the caliper brackets, but the calipers themselves. Honda used the 262 mm rotor size on a lot of models, and in the US the Prelude (97-01) and the Accords (98-02) all had 262 mm rotors. So the caliper should interchange. But again, I am not familiar with the car you have.
I also know that the 92-96 Prelude was 262mm rear and 280mm front. Atleast here in Norway (or whole EU)
I ordered a full set for my Prelude from eBay once (4 discs, 8 pads) and it turned out that the front discs didn't fit my car, since the calipers was too big (282mm)
So I think both front and rear in the US was 262mm :b
It just escalated to the interest of all the brakes, since I figured that after getting my broken calipper replaced, I might aswell swap out all 4 rotors and pads.
This is an extremely rare car, even here in Norway. And I figured such rare vehicle deserve to be taken care of! :3
Old post but adding info still.
FRONT
Front Rotor - Outer Diameter [mm]: 282.0
OEM Part Number: 45251-S0A-000
Innner Diameter [mm]: 152.0
Centering Diameter [mm]: 64
Wheel Stud Spacing [mm]: 4x114.3
Rotor Thickness [mm]: 23.2
Overall Thickness [mm]: 48.0
Other compatible vehicles: Honda Prelude SI VTEC 93-96, Accord Wagon CF6 F23A 00-02?, Accord Torneo E-CF3 F18B.
Brake Pads
OEM Part Number: 45022-ST7-R02
Dimensions: 148.6x57.7x17.5mm
Other compatible vehicles: Honda Prelude SI VTEC 93-96, Accord Wagon CF6 F23A 00-02?, Accord Torneo E-CF3 F18B, 97-01 Acura Integra Hatchback Type-R
Non-OEM part numbers: Hawk Performance HP Plus HB143N.680, Hawk Performance HB143Z.680 Ceramic Brake Pad
FRONT
Brake Pads
ansubauddy
Jul 3, 2009 11:23 AM
Westrock2000
Mar 29, 2002 07:01 AM
