JDM vs USDM wiring harness compatibility?
Hello boys
My Swap is D15B 3 stage with S40 tranny
question is: My engine wiring harness is JDM OBD2a A/T (I do not know why this engine is manual tranny but brings automatic harness from factory) and I want to connect it to the interior (main) wiring harness wich is USDM obd2a M/T...
plugs from engine harness
C101 (10 pins) & C136 (14 pins)
Female C101 plug from main harness
C101 pins
In the service manual it says that most of the pins on the C136 are A/T Controls which I will not use, because brings manual tranny...
C136 pins
This will give me trouble or not? because the JDM engine harness brings 2 connectors the C101 and C136 both male plug. And the USDM wiring harness only brings C101 female plug?
I'm practically a rookie in electronics of honda
C101 pins
In the service manual it says that most of the pins on the C136 are A/T Controls which I will not use, because brings manual tranny...C136 pins
This will give me trouble or not? because the JDM engine harness brings 2 connectors the C101 and C136 both male plug. And the USDM wiring harness only brings C101 female plug?I'm practically a rookie in electronics of honda
wizzards581
Oct 21, 2003 09:55 AM
eddiecut
Aug 17, 2003 07:39 PM
