H22 cranks, no start
Old Oct 9, 2016 | 01:36 PM
stevejames's Avatar
Default H22 cranks, no start
So I recently bought a 2000 prelude, and the guy ran through a huge puddle and sucked in some water. There's no water/oil mixed, I pulled the plugs and it was dry, and I'm definitely getting fuel. I checked the plugs for spark and nothing all the way accross. Then opened the dizzy up and everything looks dry, and in good condition. What's the next plan of action looking for spark?
Old Oct 9, 2016 | 04:36 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: H22 cranks, no start
Do a compression test and make sure all cylinders are sound. If yes, then test the ignition coil.
Old Oct 10, 2016 | 11:45 AM
fcm's Avatar
fcm
Old Fart
So no spark?
Check coil and ICM, [igniter] also check connections to coil and ICM.
Question, does tach move at all when trying to start engine?
If not, the ICM is the problem.94
Old Oct 10, 2016 | 07:44 PM
stevejames's Avatar
So I found spark today, and compression check was 90/90/40/60. It's a goner lol
Old Oct 11, 2016 | 01:40 PM
fcm's Avatar
fcm
Old Fart
Was the compression test on a hot or cold engine and was it a dry or wet test? 94
ANNiHiLATORS
Sep 6, 2009 04:05 PM
Bngo731
Jun 5, 2006 02:42 PM
rovigian
Nov 27, 2004 07:48 AM
KaRiZMa
Nov 1, 2004 04:19 AM
mugenracer
May 19, 2002 02:29 PM
