HVAC Blend Door Actuator Testing (solved)
Old Oct 9, 2016 | 04:36 AM
Jimi Hondrix's Avatar
Default HVAC Blend Door Actuator Testing (solved)
1998 Honda Civic EX coupe. A/T. 170K miles
Vent selection no longer working properly and will only blow from top vents regardless of which button/mode is selected. Metal rod to blend door is connected properly and no movement or sound of control motor when key is in position 2 and each vent modes are selected on dash. Looking for info on how to test. Part is labeled as mode control motor in attached image.
Old Oct 9, 2016 | 05:59 AM
kab00m's Avatar
Default re: HVAC Blend Door Actuator Testing (solved)
Do you have access to the factory service manual or did you pull that image from the internet? The reason I ask is because the test procedure is stated under the part description.
So, I did a quick search for you as I watch the Formula 1 race. Use the search feature next time or do what I did and use Google; the procedure has been discussed before here on HT.
https://honda-tech.com/forums/honda-...ersed-2615060/
Last edited by kab00m; Oct 9, 2016 at 06:11 AM. Reason: Used google-fu to find the answer
Old Oct 9, 2016 | 06:11 AM
Yes I have the manual and I did see the test description reference on the diagram. Just wanted to avoid the possible extensive search through the manual to find it if someone has a quick link. I found a test proceedure for 7th gens which is probably the smae as for 6th gens:
  1. Disconnect the 7P connector from the mode control motor.
  2. Connect battery power to the No. 1 terminal and ground the No. 2 terminal; the mode control motor should run smoothly and stop at Vent. If it does not, reverse the connections; the mode control motor should run smoothly and stop at Defrost. When the mode control motor stops running, disconnect battery power immediately.
MODE CONTROL MOTOR
  1. Use a digital multimeter with an output of 1 mA or less at the 20 k ohm; range. With the mode control motor running as in step 2, check for continuity between the No. 3, 4, 5, 6 terminals and the No. 7 terminal individually. There should be continuity for a moment at each terminal.
  2. If the mode control motor does not run in step 2 remove it, then check the mode control linkage and doors for smooth movement.
  • If the linkage and doors move smoothly, replace the mode control motor.
  • If the linkage or doors stick or bind, repair them as needed.
Old Oct 9, 2016 | 06:13 AM
kab00m's Avatar
And just to add, be careful when testing the motor. There is not a lot of room in there to do the test. I had a pigtail from a junkyard Civic to test mine.
Old Oct 9, 2016 | 06:32 AM
Found a related post... good ole' Ron J. on HT and his many diagrams: https://honda-tech.com/forums/honda-...civic-2816037/ I made some long jumper wires with alligator clips a few months ago when I tested the condensor fan and a/c compressor clutch coil relay so, those will come in handy. Thanks for the replies and I'll update after testing.
Old Oct 9, 2016 | 06:37 AM
kab00m's Avatar
Good to know! Curious question. Did your mode control motor quit out of the blue? Mine died after fiddling with the butchered radio harness I inherited from the previous owner(s) handy work.
Old Oct 9, 2016 | 06:43 AM
Yes, as far as I can remember..it happened several months ago however been busy with other stuff getting in the way:
condensor fan replacement
clutch coil replacement
blower motor replacement
and other stuff.
Old Oct 9, 2016 | 12:54 PM
Control motor failed test. Replaced with salvage yard OEM part ($13).. working well now.
Thanks for replies.
hound2696
Honda Civic (2006 - 2015)
23
May 8, 2018 09:43 PM
Tle111
Apr 15, 2016 09:10 PM
shaunlo233
Oct 5, 2008 03:35 PM
x4Banginx
Dec 23, 2004 10:12 PM
chibi_chas
Mar 10, 2004 08:20 PM
