injector help!!!!ASAP
Old Nov 8, 2002 | 12:20 PM
skud_dusty's Avatar
Default injector help!!!!ASAP
if i used hf injectors for a mini me in a 4th gen civic, and used an si ecu, would it run too lean?
Old Nov 8, 2002 | 12:30 PM
Urban Business
Guest
Posts: n/a
Default Re: injector help!!!!ASAP (skud_dusty)
the injectors will be fine most likely. but the pm6 will not have proper fuel maps
Old Nov 8, 2002 | 02:41 PM
skud_dusty's Avatar
Default Re: injector help!!!!ASAP (TorteX)
im not planning on using vtec until i get something to modify the air/fuel ratio. so i wont have to worry about vtec fuel maps. i should be fine with the pm6 ecu without vtec correct? and i was told that the hf injectors are too small... i need some proof that they are or arent...
i need some obd o injectors really bad!!!!!!!!!!!!!!!!!
Old Nov 8, 2002 | 03:00 PM
Urban Business
Guest
Posts: n/a
hf is mpfi correct? if so their 240cc jectors which are fine
Old Nov 8, 2002 | 04:32 PM
skunkwhat's Avatar
Default b18c whats that?
I second the 240cc of hf injector. Alot of peeps run the stock si ecu on a sohc vtec with an rpm switch or vtec controller like a fields unit.
Old Nov 8, 2002 | 06:28 PM
USDM 4G VTEC's Avatar
Default Re: b18c whats that? (skunkwhat)
all honda injectors are 240 cc except the preludes ones... HF, SI , accord, civic, all stock are 240cc
Old Nov 8, 2002 | 08:44 PM
skud_dusty's Avatar
Default Re: b18c whats that? (JDM EF9)
this is why i worship this website. thank you soo much guys. i bought a pm6 tonight for $40, and am probably going to buy the hf injectors. then run an rpm activated switch. i'll just tune my fuel system to run a little on the rich side all the time
thanks again guys. you've saved me a couple hundred bux
Old Nov 8, 2002 | 09:22 PM
Default Re: b18c whats that? (skud_dusty)
running rich.. use the Z6 FPR or an adjustable one... run about 42 psi... i run rich a lil and i passed emision with flying colors..
Damills
Mar 3, 2009 02:56 PM
adeline
Nov 16, 2007 04:23 PM
sporkcrx
Oct 21, 2006 01:07 PM
Sampsonite987
Mar 30, 2004 02:11 PM
SOHCrx
Nov 27, 2003 07:39 AM
