What would cause all 4 cylinders low compression.
Ok so my car was boosted. Drove it into driveway and worked on it for about a week to make it back all motor. After I put everything back together had a crank no start issue.
Here is what I checked :
Has spark
Has fuel
Timing is correct, I put a screw driver in cyl #1 and turned the motor counter clockwise until the screw driver didn't go up anymore ( cam gears both pointed up and the 2 - marks lined up.)
Next I check compression: All cylinders have about 110-115 psi. Put some oil into the spark plug holes, tried to start it up again. It almost fired up sounded like the compression got stronger.
You guys think its a headgasket, rings, or valves? When I was turning the motor, I heard like a hissing sound coming out, maybe from the headgasket? Because I have a header and the intake manifold on, pretty sure couldn't hear if it was the valves leaking.
Any thoughts.
Ty
And does a boosted car go through rings faster, because you want a boosted car to run a little richer, so the mixture of added fuel makes the rings wear faster? Correct or no.
Has spark
Has fuel
Any thoughts.
Ty
And yes to a certain degree, a boosted car will be tuned slightly richer to cover fluctuations in boost pressure and other variables. But a correctly tuned engine will not be so rich that you wash the cylinder walls with gas. Rings are usually taken out by pre-detonation/running lean, caused by a poor tune on the timing or fuel maps.
Got to agree with above, a leak down test is needed.
Have you checked valve lash?
Valves may be "tight" it would account for the low compression? 94
JDMkidGSR
Nov 29, 2012 06:57 AM
vinuneuro
17
Oct 20, 2008 06:17 AM
