Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2009 Odyssey engine tapping sound?
Old Oct 6, 2016 | 02:42 PM
Hawkerdude's Avatar
Default 2009 Odyssey engine tapping sound?
2009 Honda Odyssey. 94K miles. Touring edition. When you first start the car, there is a tapping sound that sounds like a valve tap. Goes away after about 2 min at idle. What worries me is that the sound is loudest from below the engine, passenger side. I'm hoping it's an accessory that's acting up and not a crank bearing. The timing belt has yet to be changed.
If you've had a similar sound, what did it turn out to be?
Will be taking the car to the shop tomorrow.
Thanks in advance.
Old Oct 23, 2016 | 06:28 PM
TyGuy88's Avatar
Default Re: 2009 Odyssey engine tapping sound?
My first thought would be too little tension on the timing belt due to a weak timing belt tensioner. As it warms up the pressure of the tensioner will increase and the noise will stop. If you haven't had the timing belt and water pump replaced yet I'd recommend doing it all at once.
Old Oct 31, 2016 | 09:04 AM
Hawkerdude's Avatar
Done. That's exactly what it was. The tensioner. Since we were pretty much due to change the timing belt anyway, we went and did it, the tensioner and the water pump.
Old Oct 31, 2016 | 05:30 PM
TyGuy88's Avatar
I'm glad to see that fixed your problem. Now you can rest easy knowing you should be good for another 100k.
Psycho719
Sep 14, 2011 04:28 AM
__oversea
Feb 17, 2008 05:15 AM
JDMoMo
Dec 29, 2005 04:45 PM
ham
Aug 2, 2005 05:17 PM
imports
Jun 25, 2003 11:44 AM
