clutch & bearings shot?
Clutch was on its way out....
downshifted to 3rd and heard a clank-clank-clank sound. Went away. And came back a 1/4 mile later and sounded like marbles in a tin can.
Towing home now. What kind of damages am i looking at?
clutch, bearings, flywheel?
its a 1995 civic ex with a B16a and S80 hydro tranny.
towing to my house....
Can you put the car in any gear? Well regardless you're going to have to drop the transmission.
Sounds like throw out bearing... Make sure to throw the old one in the garbage along with those wheels.
The real question is are you going to be doing the work? Reason I ask is because if you're having someone else do it, it's rather pointless to speculate. If you are going to do it on your own, rather than speculate you might as well just pull the transmission out as well as the clutch. If the clutch is damaged you'll know it when you see it. If it's not then the damage will be internal to the transmission (which is possible by your description). Both scenarios WILL require transmission removal.
wildcat98
13
Mar 4, 2008 10:49 AM
vtecaccordf22b1
Dec 2, 2007 04:18 PM
