99' EM1 - Rear Sway Bar Question
Old Oct 4, 2016 | 07:27 PM
vinnyme50's Avatar
Default 99' EM1 - Rear Sway Bar Question
Hey guys,
Before I get roasted, I just want to mention I did run a search on the forum and google to no avail. I know the sway bar issue has been tackled many times but I didn't find specifics on how high the spring rates should be.
I just wanted to ask what kind or rear spring rates I should be running to safely run a CTR sway bar with a subframe reinforcement.
I have a 99' EM1 with Eibach Sportlines and Eibach Shocks too. Would that be safe enough?
Anybody running the same springs with a similar sized sway bar?
If so for how long? And how are the driving conditions you experience mostly for daily driving?
I saw on the reference thread for spring rates that the Sportlines run 275lbs/in in the rear and a CTR stock is at 240.
Any help would be appreciated, I'm actually new to the forums just got the car three months ago.
Old Oct 5, 2016 | 08:02 AM
vinnyme50's Avatar
Default re: 99' EM1 - Rear Sway Bar Question
Bump. Anyone?
Old Oct 5, 2016 | 02:02 PM
98civdx's Avatar
Master Detailer
Default Re: 99' EM1 - Rear Sway Bar Question
What do you mean "safe"?
Get an ASR and put the CTR bar on it.
Old Oct 5, 2016 | 08:18 PM
vinnyme50's Avatar
I just heard that even with a brace like ASR's the rear subframe could still as easily tear out if your spring rates are low enough or if the shocks have too long of a stroke.
I know the brace is the end is the all be all solution other than welding a CTR subframe in place.
But I just want to get a good idea of what my factor of safety is from preventing tear out given my current suspension set up.
Old Oct 5, 2016 | 08:20 PM
vinnyme50's Avatar
I forgot to mention that I'm also going to be using a brace either ASR or F7
Old Oct 5, 2016 | 10:09 PM
eHMxhACk's Avatar
yippee-ki-yay
10 Year Member
Don't make it any more complicated than this.
You're not going to destroy your subframe with an ASR brace unless your subframe is rusted/rusting through.
eH.
Old Oct 6, 2016 | 02:18 PM
98civdx's Avatar
Master Detailer
It's not going to happen.
The higher the spring rates the less the sway bar will actually do.
You are overthinking a very simple job. Get the brace, bolt it on and drive the car.
VarTheVar
35
Jun 23, 2018 05:23 PM
VeilSide_Mas
Suspension & Brakes
Apr 24, 2007 12:13 PM
deviant1
10
Aug 24, 2004 05:43 AM
ion_four
Apr 20, 2003 08:45 PM
Blown90hatcH
11
Oct 8, 2002 12:59 PM
