b16a2 broken vacuum nipplet
Old Oct 3, 2016 | 05:53 PM
Type 56's Avatar
Default b16a2 broken vacuum nipplet
A good part of that nipplet broke off while i was messing with it earlier. Now it's sitting flush inside the manifold and i can't seem to able to get it out to have it replaced with a new one. Should this be something i should be worry about?
Old Oct 3, 2016 | 08:05 PM
Fishy_hondaman's Avatar
Default Re: b16a2 broken vacuum nipplet
looks like its bent from the photo,
drill it out and jbweld a new one in there. Or maybe they make a tapered one. Id just jb weld a vacum metal one in there dont use too much.. take off the whole intake manifold too if your drilling it out
or maybe get a skinnier one in there and jbweld it somehow.
or jbweld it shut and make another custom vacuum line somewhere else on the intake manifold or sumthing
Old Oct 3, 2016 | 08:07 PM
Type 56's Avatar
That's just an example photo i found on the web. Mine is really broken off.
Old Oct 4, 2016 | 03:42 AM
holmesnmanny's Avatar
Well obviously you gotta get it out, use a long magnet after taking off the throttle body to get it out. You could even try to get to it through the iacv hole, depending on your magnet. I would just try to jb weld it back on.
Old Oct 4, 2016 | 08:49 AM
Type 56's Avatar
I got it off now. All i had to do was tap it out with a small screw nail and then, pliers to yank it out with afterward...Problem solved!
98civicEX
Aug 13, 2009 02:11 PM
Attoir
May 21, 2006 06:36 PM
sadangryboi
May 3, 2005 05:38 PM
Special B
Jul 21, 2004 12:02 AM
Jx3069
Aug 27, 2003 07:21 AM
