How to reinstall power steering into a 2000 Civic CX?
Hello all,
Yesterday I purchased a 2000 Honda Civic CX Hatchback for $400 with intentions of using it as a winter beater.
I test drove it, and decided that I want to reinstall power steering.
My question to you guys; What is needed to complete this? How difficult would it be?
Thanks in advance!
Thanks in advance!
Hello all,
Thanks in advance!
Thanks in advance!
You will need:
P/S Rack
P/S Pump w/ bracket
Crank pulley with accessory pulleys attached
Belt
High side line (pressure, has sensor in it, need that too)
Low side line (suction)
Reservoir
P/S cooler
P/S cooler hose
uhhh I think off the top of my head that's everything.
Me personally I don't think it's all that hard to do, but I am a Honda Technician and work on these cars every day. Hardest part would be if you needed to replace the current rack.
-Amp
Depends on what's currently left. Re-installing, so it had it at one point?
You will need:
P/S Rack
P/S Pump w/ bracket
Belt
Reservoir
P/S cooler
P/S cooler hose
-Amp
You will need:
P/S Rack
P/S Pump w/ bracket
Belt
Reservoir
P/S cooler
P/S cooler hose
-Amp
If you look at the steering rack in the engine bay and it has hoses going to it, it probably had power steering at one point.. but most likely it came with a manual rack.. i don't think the cx's came with power steering.. so yeah you would need all that stuff
I believe the automatic cx's came with P/S. From what I've seen though the 5-speed ones did not. Also, an easy way to tell is measure the steering wheel across. The manual rack cars came with a larger diameter steering wheel. My CRX steering wheel is huge! haha
-Amp
-Amp
EDIT: Nevermind, with that RSX wheel it probably is ridiculously hard to turn...
-Amp
The CX with manual trans came from the factory with a manual rack. The stock steering wheels are all the same size in those cars.
If you want to add power steering you'll need a manual rack, the U-joint at the bottom of the steering column where it connects to the rack, all lines and associated brackets, reservoir, pump and steering pump bracket. You may also need a crank pulley, I know the '88 - '91s and '92 - '95s without PS don't have the 3rd pulley to run PS. I can't remember if '96 - '00 is the same or not. You will need to remove the subframe to get the rack out. It's not a horrible job, just somewhat time consuming and you'll need an alignment when you're done.
I'd suggest you get a stock '96 - '00 Civic steering wheel or '97 - '01 CR-V Steering wheel and leave the rest as is. Once the snow is on the ground you really wont notice the lack of PS at all.
you don't need to pull the subframe to replace the rack. you can slide the manual steering rack out with some maneuvering and then slide the power one in.
94EG8 listed all the parts you need. do not forgot that Unijoint that connect the steering rack to the wheel. The manual rack has smaller splines than the power one!
it's a really straight forward job. Just get the stuff, hook it up and you're good.
The hardest part for me was making sure i had the rack and steering wheel centered before i locked everything in place.
You don't need to worry about hooking up the pressure sensor on the high side of the PS lines. Just leave the sensor in the line and keep it disconnected.
Its just for a warning light as far as i know anyway. Mine's never been hooked up in almost 8 years of ownership.
Espiritu204
May 23, 2016 12:56 PM
Azn_Empurio
10
Aug 30, 2005 07:19 PM
Lookincrazy
Dec 27, 2001 05:47 PM
Lookincrazy
15
Nov 27, 2001 08:13 PM
