Deep knocking noise while turning
My civic (98 dx 4dr manual) developed a deep knocking noise while turning. My cv boots don't seem to be ripped or torn. My tie rods have tears in them though, and will be replaced soon. Any idea on if you can develop a knock or skip while turning from poor alignment due to worn tie rods? When I hear bad CVs I normally associate that to a ticking while turning. This is more of a grunt, which makes me think of misalignment. Also, if I replace my outer tie rods myself, how can I ensure my alignment is close enough to straight so i can drive it far enough to get a proper alignment. Thank you!
Also, would one bad cv produce knocking or ticking when turning both left and right? Because when I turn, the sound comes from which ever wheel is on the interior of the turn
It can be inspected on the ground. If the shaft of the axle in question is moving around its a possibility that the joint is fubered.
picthis1
Feb 1, 2012 08:32 PM
lllg3n0c1d3lll
Jan 20, 2010 10:36 AM
96hondaAccordV6
Apr 24, 2007 02:15 PM
