Engine overheating still. Any thoughts why?
Old Sep 25, 2016 | 04:32 PM
SupremeDalek209's Avatar
10 Year Member
Default Engine overheating still. Any thoughts why?
Hello I have a 89 prelude that overheats. I just bought it last week and I'm trying to figure out why it's overheating. I drained the coolant added new coolant, installed a thermostat after it didn't even have one. I'm thinking maybe it has the wrong fan switch, since I haven't seen the car turn on the fan unless I drive, and when I drive it over heats after around 5 minutes of driving. I have no leaks since all hose is 2 years old so I'm stumped. Anyone have any suggestions? Maybe water pumpump?
Old Sep 25, 2016 | 04:33 PM
10 Year Member
Default Re: Engine overheating still. Any thoughts why?
Btw after I drive and park it and turn the car off the fans are on. That's the only time I noticed the fans on when the car isn't moving.
Old Sep 26, 2016 | 12:29 AM
holmesnmanny's Avatar
compression test to see if the head is warped and letting combustion gases into the coolant
Old Sep 26, 2016 | 08:13 AM
fcm's Avatar
fcm
Old Fart
The fans turning on after engine is turned off is most likely the rad fan control unit turning them on because oil temp is up.
My guess is the ECT switch is bad, to check, unplug the switch and jump the terminals in the plug, to see it rad fan turns on, if they do, replace the switch, if not check wiring between switch and rad fan relay.
As mentioned a compression test needs to be done, overheating within 5-10 min. is not very common. 94
Old Sep 26, 2016 | 04:38 PM
10 Year Member
Ok thank you both. I will try these methods out from what you both said.
torino420
May 5, 2013 08:07 AM
nyhondaguy
Honda CR-V & Element
Dec 28, 2012 09:12 PM
yangtech
Oct 6, 2005 06:44 PM
sivicstyle
May 29, 2004 07:18 AM
HybridKOOP
Aug 14, 2002 11:08 AM
