Rise of the turd (EG turbo)
Old Sep 21, 2016 | 11:58 PM
davidnilsson's Avatar
Default Rise of the turd (EG turbo)
Bought this civic in 2014 to use as a A-B car but i really enjoyed driving it so i started doing som turbo stuff and getting some carbon parts
It still have the stock d16z6 engine that has never been opened, producing 217whp with a gt3076 at about 10psi.
The first turbo build gt2871 turbo and fmu, homemade turbo adapter
2014
2015. bumper exit exhaust!
2016. mini ram,gt30,440cc,chrome etc.
2016
2016 september.
Old Sep 22, 2016 | 09:06 AM
TheShodan's Avatar
Moderator
Default Re: Rise of the turd (EG turbo)
Interesting snapshot
Old Sep 22, 2016 | 04:02 PM
Geis's Avatar
Wow, that graph looks really nice, especially considering it's a D series.
Old Sep 25, 2016 | 11:32 PM
Yeah i think so to, i am really satisfied with the curve and numbers
Old Sep 26, 2016 | 03:54 PM
wantboost's Avatar
Who is Mr Robot?
Gt378 on a stock d series to make only 2xx hp is soooooooo overkill. Has to be incredibly laggy for the power it makes.
Old Sep 26, 2016 | 09:36 PM
Its a gt3076 and it is not that laggy, i have had worse and also i like lag haha. Overkill it the depends on what character you want u know, and it saves the engine and gearbox to not have so much power/nm on low rpms Rather big turbo with low boost then small turbo with high boost.
Old Sep 27, 2016 | 10:54 AM
mrdrpep's Avatar
I agree with you on this. I used to have a ZC (blacktop d16a9) with a small turbo (IHI RHB5) in my CRX and it was a blast to drive through all the RPM's. So I was a little hesitant later when I put a .63/60 T3/T4 on my B16. I did not want all the lag but it still feels really good even between 2800-3500 normal driving. The gear ratio's are close enough on our little Honda's that it's easy to get into the boost when you need it.
Old Sep 27, 2016 | 12:16 PM
2kdrift's Avatar
to you it may not be "laggy". what hes saying is there are lots of better options at this power level. at this level GT3076 its not even in its efficiency zone. Contrary to popular belief you get better responsiveness at higher boost levels and a smaller turbo
to each their own. as long as YOU are happy with it. Still doesn't change the fact that it is far from optimal
Old Sep 27, 2016 | 01:09 PM
mrdrpep's Avatar
^ I personally wouldn't go bigger than a td05h on a d-series, and a .63/60 on b-series for a daily vehicle. I didn't know how big the gt3076 was...
Old Sep 27, 2016 | 11:29 PM
I was not aiming for an optimal build just a budget build for fun and i used the gt3076 because i got it cheap and it was an interesting experiment to see if it spooled at all. I drive alot of 201m races (1/8 mile?) and it has been good to not have boost on lower rpms for the grip actually. My goal was to beat my friends FK2 type-r (310hp) on 1/8 mile and it does so i am happy
Old Sep 27, 2016 | 11:32 PM
Ok, my friend has a holset hx40 on his built b16a2 and it spools pretty well i think. Maybee i will try a smaller turbo next year to experience the difference
Old Sep 28, 2016 | 09:09 AM
LightningTeg's Avatar
Community Builder
Your missing out on fun for sure
Old Sep 28, 2016 | 11:27 AM
2kdrift's Avatar
I and it has been good to not have boost on lower rpms for the grip actually.
Less traction issues with a smaller turbo....just so you know
I have a turbo comparable to the gt3076, at 17PSI running a ITR transmission. My only traction issues are at higher RPMS in the 5-6K range no problems at all in the lower RPMS
75aces
29
Dec 19, 2011 02:38 PM
louisiana CRX
Dec 1, 2008 04:11 PM
typeRSXS
Oct 3, 2003 07:25 AM
mr2
13
Nov 8, 2001 11:01 PM
