This is a swap ready shell, I don't drive it much anymore so I've decided to move on and start the partout. The suspension on the car works, from a 60 roll I can put down all the power (900+hp) and it goes straight. If you don't have the money please don't waste mine or your time asking a million questions. I don't mind helping someone out that would want more information on doing a swap in the future but please remember I'm trying to sell something here lol.
Everything that it comes with is listed below, if you don't see it listed then it doesn't come with it.
92 mr2 sunroof car non turbo.
Hux Racing motor mounts.
Hux Racing Lower control arms.
Coilovers made by me, similar to Hux Racing with KYB inserts.
Carbon fiber hood.
10 gallon fuel cell with fuel line's.
Boost controller.
"One" kirkey Racing seat with harness.
Driveshaft shop 5.9 axles and hubs with arp extended studs.
Heat exchanger with water pump with line's and ice box.
Wheel's (Fronts only) XXR, plasti dipped black.
Wilwood big brake kit.
New turbo rear brakes.
ST Rear sway bar.
Shifter and cables for k20 trans and adapter for shift linkage.
Mishimoto aluminum radiator with dual fans.
Battery, chassis wiring, fuses, Cluster is cut for a racepak dash.
Pretty much swap in your motor, transmission, fuel pumps, engine harness and ems. Does not come with rear wheels, I'd like to keep them. I will sell the wheel's and tires (M&H 275/50) for $800 more than listed price.
The paint is only a 3 year's old. Dude painted it in the dark or something before I bought the car from him so it's not the best looking lol. It's not that bad but I'm picky, which is why the car was Plasti Dipped white (back to gray now). The body is straight, has a small rust spot on the lower kick panel in front of the driver side rear wheel. I'd like to get $5500 for it, which is less than half of what I have in it as a swap ready shell. Video of walk around I took today since the car is still together at this point.
