Valve Cover Question!
Old Nov 8, 2002 | 09:14 AM
lildrgn2.0's Avatar
New User
Default Valve Cover Question!
Ok. As most of you know, I finally got the lude back together, with the help of HONDA, and some notes from Todd. Well.. I noticed today when i opened my hood that there was a mild oilspray on the underside of my hood and on the back side of my valve cover. I look around the valve cover and see that the nut that is in the back center of the cover that holds the cover on, has no washer underneath it. I still have enough oil, although i was getting low. What all problems can this cause? I have driven it 100 miles since its been back together, so I am just wandering if anything can be damaged with it not being sealed right there (other than lack of oil)
Thanks
Mike
Old Nov 8, 2002 | 09:18 AM
2point6's Avatar
Default Re: Valve Cover Question! (Lildrgn)
As long as you didn't run out of oil, you should be ok. Just replace the washer and clean up the mess.
Old Nov 8, 2002 | 09:22 AM
lildrgn2.0's Avatar
New User
Default Re: Valve Cover Question! (2point6)
*wipes sweat from forhead*
Old Nov 8, 2002 | 11:21 AM
lildrgn2.0's Avatar
New User
Default Re: Valve Cover Question! (PreloodDude)
are you sure your oil filter is properly tightened? b/c that will give you oil spray under the hood.
j/k.
i'm suprised you lost oil though just because that (plastic ?) washer wasn't there. i thought i had gone without a couple of those before and not run into trouble.
well you can see that there is an opening that a washer would cover if it were there.
The nut does not even reach the valve cover so there is a good size space between the bottom of the nut and the top of the cover.
Old Nov 8, 2002 | 11:59 AM
tim.simpson's Avatar
I lost one of those washer things too once. You will lose oil out there all the time coz of compression in the crankcase. It an't no ordinary washer either, its half rubber seal(shaped to fill hole) and half metal. Honda only part I'm affraid. Next day delivery about $5 each. I temporarily used a rubber washer and metal washer on top and it still was wet with oil around the washer after only 10miles.
Get the parts...
Old Nov 8, 2002 | 12:18 PM
Sephro's Avatar
Default Re: Valve Cover Question! (tim.simpson)
When I replaced my valve cover gasket, I went to NAPA and got the whole kit with those washers for under the bolts, the pieces around the plugs and the gasket for around $30
Maybe you can buy just the washer things there too??
Old Nov 8, 2002 | 01:04 PM
MPower332TI's Avatar
Default Re: Valve Cover Question! (Sephro)
haha. it happened to me and it sucked. i was like what the hell. where is this oil coming from. then replaced the washer.
the king.
12
Feb 3, 2009 08:29 PM
aleks77
Jul 11, 2007 04:49 AM
Shaguar47
Feb 11, 2005 06:28 PM
J337_UNIT
Sep 4, 2003 12:47 PM
