Intercooler pipe knocking - recommendations of protection from erosion from rubbing
Old Sep 10, 2016 | 05:19 PM
Sprockets's Avatar
Default Intercooler pipe knocking - recommendations of protection from erosion from rubbing
There's a slight knocking noise on/off throttle and when I start the car that I'm fairly certain is the intercooler piping. On my previous setup, I put adhesive foam in the areas that were touching, but it wore through in no time. Is there something more durable that I can use? My Hasport motor mounts only have a bit over 2,000 miles on them, so that's not the problem.
Old Sep 10, 2016 | 06:30 PM
B and B's Avatar
Loved
Community Favorite
Default re: Intercooler pipe knocking - recommendations of protection from erosion from rubbing
As a quick fix, I split some vinyl tubing and made a grommet, cuz mine was where it passes through the fender well..(EG/EH)
Then during my top end refresh this spring, I discovered a gnarly *** half inch almond shaped hole rubbed thru my aluminum charge pipe. The vinyl was harder than piping.
Had been repping like that for months, (no wonder a three valve hung with me with my passenger.)
I fixed all the questionable unions, bought a 90 couple for turbo outlet, and adjusted so there were no points of contact.
Now I can use all 8 lbs. of boost!
God, I suck, with my obsolete S200.
Old Sep 11, 2016 | 04:02 AM
IN VTEC's Avatar
I wrapped the couple of spots that come close to the chasis with header wrap. It also helps with heat rejection.
Old Sep 11, 2016 | 05:49 AM
Sprockets's Avatar
LOL, why vinyl? I split a piece of fuel hose and it's held up for nearly 15 years. I originally had a Greddy kit that came with an aluminum bracket which bolted to the chassis. It eventually snapped in half. I wish there was a way to support it without being too rigid to the point where it can break.
I was thinking about header wrap, but it seems like a pain to work with because there's no adhesive.
Old Sep 12, 2016 | 11:45 AM
2kdrift's Avatar
wrap the pipe and secure with safety wire
Old Sep 12, 2016 | 11:53 AM
testify's Avatar
On vacation
Split a piece of rad hose and secure it with zip ties.
Old Sep 13, 2016 | 10:23 AM
Sprockets's Avatar
Thanks guys, I've decided to try header wrap.
Old Sep 13, 2016 | 04:28 PM
B and B's Avatar
Loved
Community Favorite
I looked at my hose scraps and only had clear vinyl from something, didn't have fuel hose laying around....
anyway, I figured it would cushion.
The best way is not to have any contact points like it is now, clean! **** can move all it wants now.
Old Sep 13, 2016 | 05:27 PM
IN VTEC's Avatar
Default Re: Intercooler pipe knocking - recommendations of protection from erosion from rubbi
wrap it tight and hose clamp the ends
Old Sep 13, 2016 | 07:17 PM
B and B's Avatar
Loved
Community Favorite
Or Home Depot sells the stainless ties as Cable ties for $6
My wrap gave up long before these did. Well, they never did, had to cut off.
Old Sep 14, 2016 | 07:32 AM
Sprockets's Avatar
Perfect, thank you! Is 11 inch the right size for 2.5" piping with DEI Titanium Wrap?
edit...
I just found these for cheap:
https://www.amazon.com/Vktech-100pcs-Stainless-Exhaust-Locking/dp/B00CTKBTH2/ref=sr_1_3?ie=UTF8&qid=1473869578&sr=8-3&keywords=header+wrap+ties
I pay more attention to the negative reviews, which mention that they back off a bit after you tighten them. I wonder if this is common with all these types of cable ties, rather than the brand.
LOL, who edited the subject in my thread to "erosion"?
Old Sep 14, 2016 | 10:00 AM
LightningTeg's Avatar
Community Builder
Yes those tie wraps are pretty much useless in my opinion unless you have the special tool for tightening them. I've tried every which way from Sunday and they always loosen on me. I prefer regular hose clamps even if they appear less appealing to the eye.
Header wrap will rub off in no time. Check this stuff out. I've used it in some projects at work. Has great form-ability, has a slick surface and very abrasion resistant:
McMasterCarr #: 8997K21 , the softest durometer I believe
Old Sep 14, 2016 | 10:57 AM
boosted94gsr's Avatar
I've had the same experiences with those ties, hose clamps work great for me too.
Old Sep 15, 2016 | 05:29 AM
Sprockets's Avatar
Thank you for the link, but I already ordered some DEI header wrap. Hopefully, it holds up. That stuff on McMaster is expensive! $60+ for one square foot? I guess if there's a stubborn area, I can try a smaller piece.
Old Sep 15, 2016 | 06:04 AM
Community Builder
The 6x6 is $18. I know that header wrap is $50 + for roll and its not really made for that purpose.
Old Sep 15, 2016 | 06:48 AM
Sprockets's Avatar
I got a 33' roll for $25 on Amazon. I had ordered it before you posted, so I'll go ahead and use it for now. If and when it grinds through (or "erodes" from years of water rushing through there, lol), I'll order the 6x6 piece.
Since this is going to be hidden inside the fender and bumper, why can't I just use thick plastic zip ties, rather than hose clamps, etc.?
Old Sep 15, 2016 | 10:34 AM
EsotericImage's Avatar
Retired Moderator
I used vacuum hose, split it down the middle, placed it over the sharp metal and worked fine.
Use hairspray to keep it in place or some sort of adhesive if it keeps moving.
This is also good for aftermarket radiators that hit the brace in the corner.
Old Sep 15, 2016 | 02:27 PM
Plastic zip ties will probably work just fine for intercooler piping, but I still think worm clamps will hold the best. Especially inside the fender/bumper where it's never going to be seen anyways.
Old Sep 16, 2016 | 07:34 AM
Sprockets's Avatar
I did the same thing on my last radiator, and now my PWR is doing the same thing. Thanks for reminding me!
That's a good point. I just thought the worm clamps might be bulky and possibly be another source for metal on metal contact. I'll try the worm clamps first.
tegGOTboost
Jun 16, 2005 05:02 PM
Boost Addict
Sep 24, 2004 10:12 PM
Btothe3rdDegree
Aug 26, 2004 09:57 PM
RedTegLS
Oct 14, 2003 04:12 PM
NeXtLeVeL_TyPe_R
Apr 17, 2002 09:38 PM
