OBD2B D16Y8 into 96 Civic auto
Old Sep 10, 2016 | 12:52 PM
jg203306's Avatar
Default OBD2B D16Y8 Automatic into 96 Civic EX AUTOMATIC
Been searching and can't find what I'm looking for.
2 issues
If I adjust the bolt holes so that 2 bolts will screw in, will the TD80U distributor work?
Will an OBD2A auto ex ecu work without modification for this engine?
Old Sep 10, 2016 | 02:19 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: OBD2B D16Y8 into 96 Civic auto
What make and model do you have now?
Old Sep 10, 2016 | 03:27 PM
jg203306's Avatar
A 96 Honda Civic, lol
Old Sep 10, 2016 | 03:29 PM
Technical Hero
Ex, DX, LX, CX, HX? Is the Y8 auto? Does it come with the EX trans?
Old Sep 10, 2016 | 03:47 PM
jg203306's Avatar
Oh. It's an EX, EX trans. Y8 is auto.
Old Sep 11, 2016 | 01:13 PM
Technical Hero
For simplicity sake as long as the new engine is from an auto just reuse your alternator and ECU.
Old Sep 11, 2016 | 03:00 PM
jg203306's Avatar
The distributor is the issue, not the alternator.
Old Sep 11, 2016 | 03:08 PM
Former User's Avatar
This thread is a complete mess because you failed to provide all required car information in your first post.
https://honda-tech.com/forums/honda-...modifications/
Use the distributor from the 96 Civic EX auto.
Old Sep 11, 2016 | 03:28 PM
jg203306's Avatar
What did I leave out? I'm trying to put an automatic obd2b d16y8 into a 1996 civic ex automatic. I don't know why this is confusing....
Old Sep 11, 2016 | 04:10 PM
Have you read your own thread? Trim/engine for your 96 Civic and the transmission coupled to the OBD2B D16Y8.
Complete mess. Read the forum Rules.
Old Sep 11, 2016 | 04:41 PM
Technical Hero
Sorry I meant distributor
Old Sep 11, 2016 | 05:31 PM
jg203306's Avatar
Did you read the title? Engine is d16y8, also says auto in the title. Didn't know the model mattered since all the obd2a models use the TD80U distributor....
Old Sep 11, 2016 | 05:33 PM
Reading comprehension defeats you.
This thread is done.
jg203306's Avatar
The bolt holes don't line up properly, which is why I'm trying to figure out if I can modify the ears on the distributor to make it bolt up and if it will work properly with the obd2b engine.
alecmesa96
Jan 20, 2017 05:16 AM
jdeemseerx
Feb 28, 2007 09:35 AM
crxnonvtec
Dec 22, 2005 10:44 AM
Hatebreed215
Sep 28, 2002 07:51 AM
