Shaky ride at high speeds
Old Sep 5, 2016 | 08:34 PM
mmorgan94's Avatar
Default Shaky ride at high speeds
I have a 98 Honda Accord and a couple weeks ago, I had a flat tire in the front and after my dad repaired the tire (noticed there was more wear on the inner part of the tire), I noticed that the steering is somewhat shaky when you drive over 70 mph and it wasn't like this before. What could the problem be?
Old Sep 5, 2016 | 08:36 PM
testify's Avatar
On vacation
Default Re: Shaky ride at high speeds
Your tire is no longer balanced on the wheel, or the wheel is bent.
Old Sep 5, 2016 | 08:41 PM
mmorgan94's Avatar
OK thanks, probably needs a tire balancing. I heard tires should be balanced whatever you repair or get new tires, is that true?
testify's Avatar
On vacation
Yes.
Old Sep 7, 2016 | 07:43 PM
LightGesture's Avatar
Tie rods could help a TON.
If there loose, you could have weak to strong amounts of play, making it easier for things to shake. Cheap fix. Then get an alignment, which probably needs to be done by now, assuming you're an average person like me...
parsapour
Jan 6, 2019 12:35 PM
ekmushi_mushi
12
May 27, 2009 12:00 AM
vietkangta
Apr 16, 2007 02:53 PM
erikiksaz1
Sep 2, 2006 01:52 PM
rjr162
Jul 4, 2003 11:51 PM
